cfm? for a 68 383hp carter cvs carb #1826418
05/14/15 02:51 AM
05/14/15 02:51 AM
las vegas,nv
mopar muscle7271 Offline OP
Easily triggered
Easily triggered
las vegas,nv
whats the cfm on a 68 383hp carter cvs carburetor with number 4401s? is it a 625cfm or 650cfm carb?
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826421
05/14/15 03:10 AM
05/14/15 03:10 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think they rated it 625, actual cfm was more like 590ish.
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826423
05/14/15 03:43 AM
05/14/15 03:43 AM
las vegas,nv
Easily triggered
Easily triggered
las vegas,nv
i heard 625cfm then also heard the 68 383hp stamp engines had a 650. which i have 68 383 with hp stamp on it. apparently this carb came on the 383hp engines?
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826424
05/14/15 03:48 AM
05/14/15 03:48 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think the throttle bore size and Venturi size are all the same HP or not in fact according to my 68 service manual the 340 625 avs is jetted identical to the 383HP 625 avs carb.
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826429
05/14/15 04:10 AM
05/14/15 04:10 AM
las vegas,nv
Easily triggered
Easily triggered
las vegas,nv
oh ok true on that alright,really didn't know that.wonder why people say that the 383hp engine had a 650cfm on them?
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826430
05/14/15 04:14 AM
05/14/15 04:14 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I could be wrong, maybe someone else will chime in.
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826432
05/14/15 04:27 AM
05/14/15 04:27 AM
las vegas,nv
Easily triggered
Easily triggered
las vegas,nv
im not sayin your wrong,i just saw that other post someone a post between a AFB or AVS Carb identification. he has the same carb number.they told him it was a 625 cfm as well. i would like to hear more opinions about this carb tho.
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826455
05/14/15 08:27 AM
05/14/15 08:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
none of those factory avs's had a cfm rating. but, if i had to rate a 340/383 avs i'd say close to 650cfm. one of the mopar magazines some years back flowed a 440 avs at 715cfm.
Re: cfm? for a 68 383hp carter cvs carb [Re: lewtot184] #1826461
05/14/15 08:45 AM
05/14/15 08:45 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://www.tocmp.com/manuals/Carbs/Carter/Chrysler/1965-1979/pdf/Chrysler121-173.pdf
Carter rated the 383 AVS @ 630 CFM in '70, same throttle bore and venturi size as the '68.
Re: cfm? for a 68 383hp carter cvs carb [Re: mopar muscle7271] #1826555
05/14/15 12:10 PM
05/14/15 12:10 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Because it's all about SIZE ... BIGGER is BETTER
