90 Dakota running issues, codes
#1825262
05/12/15 10:32 PM
05/12/15 10:32 PM
Posts: 10,670 Freeport IL USA
poorboy
Freeport IL USA
I recently changed the 3.9 in my 90 Dakota with a 3.9 from a 91 Dakota. The car starts pretty good and idles great, it even pulls pretty good when your in the throttle (well for a V6 anyway). The issue is when you maintaining a consistent speed. It has a very bad surge. At highway speeds it almost acts like its dieing and restarting (its a manual trans), in town it feels like a bucking bronco, the whole car will jerk forward and backwards. This is a new with the motor swap thing, I believe. The old motor last ran last summer, and I swapped in the "new" motor before i drove it this year. The old motor was tired and was burning oil and antifreeze, and would not idle below 2500 rpm the last time I drove the car with the old motor.
We took the car on a 400 mile weekend (it was running much better at the beginning, towards the end it was getting worse). We did pull almost 20 mpg. The check engine light did come on a couple of times, but went off without shutting off the motor
When I swapped in the "new" motor, I changed the intake gaskets, installed a new thermostat, new plugs, the throttle body gasket, changed the valve cover gaskets, and replaced the O2 sensor. I used the Throttle body off my old motor, and the year old plug wires & cap.
There is a cat converter, and the evap system is not connected, the solenoids are on the bench, there is no carbon canister. The egr valve is riding along.
I did the key on/off thing and am getting the following codes in the order they appeared. 12 36 52 32 31 21 41 55 Any input on what to start looking for? I have already recheck to make sure all the wires and grounds are properly connected, and I scrapped off the paint under the ground wires. Help! Gene
Re: 90 Dakota running issues, codes
[Re: poorboy]
#1825357
05/13/15 12:17 AM
05/13/15 12:17 AM
poorboy
Freeport IL USA
The egr valve is disconnected from everything except where it bolts onto the manifold.
I thought it was strange the codes flashed out of sequence too, but I went through the process 2 times and it did it the same both times. I don't have a code reader.
Back in the mid 80s I used to work on the Chrysler efi stuff, but its been so long I've forgotten most of what little I knew. The old standard was that if the computer did something wrong, it was defective, is that still the case?
I do have the computer from the truck the motor came out of, but it was an auto, and mine is a 5 speed, Will the auto computer work on my 5 speed truck?
The truck the motor came out of was wrecked. I did drive it around the yard before the starter crapped out, is it possible the dist is part of the issue? I used the one from the wrecked truck, I still have the original from my truck. Is it possible I have an intermittent loss of ignition? What is code 36? 12 should be battery disconnected. 52 is O2 too rich or open 21 is O2 rich or open (only one O2) 32 should be evap, since there are no evap solenoids, these two make sense. 31 should also be evap 41 is gen field not switching properly 55 is end of test.
Is this correct? I did have to change the plug on the new O2 sensor, I used butt connectors & changed wires one at a time in sequence, matching the wires to the same pins. Could that be the issue? I haven't had time to mess with it today, but might have some time tomorrow. Gene
[Re: poorboy]
#1825457
05/13/15 03:10 AM
05/13/15 03:10 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
code 36 is solenoid coil circuit (air switching)
code 32 is computer didn't see change in air-fuel ratio when egr activated - check valve, vacuum lines, and egr electrical
41 is alternator field control circuit open or shorted
