Re: My Powermaster Alternator mock up,.. whats wrong here?
[Re: Adam71Charger]
#1824552
05/11/15 09:57 PM
05/11/15 09:57 PM
RapidRobert
going by the last pic if you mix/match spacers/washers till the alt is moved rearward till the pulleys line up (which you know has to be done) then is there any way you can get the swing arm bracket to line up? I know I am missing something but I wanted to give my buddy a BTT start
[Re: Adam71Charger]
#1824574
05/11/15 10:26 PM
05/11/15 10:26 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I just put a factory alternator on my car not ten minutes ago.. All the brackets look like they are in the correct spot. I even have eddy heads as you do.. Must be the curvature of my alternator that lets it fit. Kevin
71 gtx.....
[Re: Adam71Charger]
#1824585
05/11/15 10:41 PM
05/11/15 10:41 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Cut off that triangle shorter and drill another hole in it to line up with the lower hole in the head.....hole mess should be closer to the motor, for a cleaner look.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Ply72rr]
#1824648
05/11/15 11:43 PM
05/11/15 11:43 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I need the power. Electric fans, fuel pump, stereo.
This alternator looks similar to the denso, and as many stores sell a bracket kit for the denso, Im hoping it might work for mine.
The alternator swings out too far because that is the only position it will line up with the swing arm enough to get the bolt through, it will not slide down the swing arm, the geometry is wrong.
[Re: Adam71Charger]
#1824695
05/12/15 12:49 AM
05/12/15 12:49 AM
RapidRobert
The alternator swings out too far because that is the only position it will line up with the swing arm enough to get the bolt through, it will not slide down the swing arm, the geometry is wrong. OH OK I see what you are saying now. I'm assuming the crank/wp pulleys are in line with each other & you just need to get the alt in line. I'd move that short spacer & get the alt in line then do what you gotta do to alter the swing arm. & I would want the alt move closer in the the eng CL & in doing that if that particular alt needs to come forward to clear the head to do so then I would & then the crank/wp pulleys need to come forward then & there are flat spacers for the crank/wp then same thing do what you need to do to the swing arm. As mentioned if you can redrill the triangle bracket so to use a lower head face boss I would do that first.
[Re: RapidRobert]
#1824755
05/12/15 02:44 AM
05/12/15 02:44 AM
Adam71Charger
Robert, the alt has plenty of clearance even with the small spacer moved up front. You're right about the swing arm, it has to be changed or modified. The stock swing arm bends forward, so once I put the small spacer in fron of the alt, the alt moves back about 3/4". So, I think need a swing arm that bends to the rear, and also has a different curve that matches the curve of the alt motion. I saw this setup on AR engineering website, see how the swing arm bends to the rear? Im going to email and see if it is what I need. http://arengineering.com/products/denso-60-amp-kit-big-block/
[Re: Adam71Charger]
#1827506
05/15/15 09:21 PM
05/15/15 09:21 PM
Adam71Charger
So, I figured out the problem. The 2 bolt hols on the powermaster are closer together than the stock alt bolt holes. So, the swing arm curve doesnt match up. I sent the alternator back, and ordered the 120idle/150cruise from qualitypowerauto.com It was a little more than the powermaster, but higher output, has same bolt distance dimensions as stock chrysler alts, and coolest part is I got it in dual field 3 wire configuration! Ill let everyone know how it fits. $325 total with free 3 day shipping. http://www.qualitypowerauto.com/item_557/Chrysler-Mount-Mega-Amp-Alternator.htm
