clearancing 440 block for 4.25 crank #1823156
05/10/15 12:57 AM
05/10/15 12:57 AM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
I am thinking of using a 4.25 over a 4.15 stroke crank.
How much clearancing of the block is needed,any pictures?
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1823193
05/10/15 02:52 AM
05/10/15 02:52 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
If the 4.25 stroke crank has 2.2 BBC rod journal dia., it may need no clearance work at all. If using a internal oil pick-up you will probably have to do a little work in block where it screws in.
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1823340
05/10/15 11:12 AM
05/10/15 11:12 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I have the 4.25 crank in my 57 truck. As stated above, I only had to do a little grinding where the oil pickup screwed into the block.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: clearancing 440 block for 4.25 crank [Re: rattler] #1823344
05/10/15 11:21 AM
05/10/15 11:21 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Would a 4.15" stroke using 2.20" rod journals likely be a "no grind" installation?
Re: clearancing 440 block for 4.25 crank [Re: BradH] #1823352
05/10/15 11:30 AM
05/10/15 11:30 AM
NC
440Jim Offline
440Jim  Offline
NC
I agree that with steel rods, the 4.25" stroke with 2.2 Chevy journals only needs a touch on the oil pickup boss. Attached pic is all I needed. You should also check for clearance at the bottom of each cylinder to the rod bolts. But they may clear without any grinding at that location.
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1823441
05/10/15 01:09 PM
05/10/15 01:09 PM
AndyF Offline
AndyF  Offline
I've built a few of those 505 inch motors over the years. I think it is probably the easiest and best BB stroker combo going. 4.250 crank with 2.200 rod journals then buy either 6.800 or 7.100 long BB Chevy rods and matching pistons. Very little bottom end clearancing needed. Maybe a slight touch on the oil pickup boss and maybe a slight notch on the bottom of the cylinder walls depending on how big the connecting rods are. If you use a high quality I beam rod you usually don't need any clearancing. The cheaper H beam rods are a little bulkier and might require a few minutes of grinding.
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1824030
05/11/15 10:06 AM
05/11/15 10:06 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I'm building one right now. Eagle crank, chevy rod. I put the crank in and the rods cleared fine so I went on with the build but noticed after I put in four pistons the counter weights are very close in a couple spots. I searched on here and found a post from BG a while back where he said some blocks need clearance for the counterweights and some don't. I have to pull mine apart, clearance it, clean it and try it again.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1824068
05/11/15 11:14 AM
05/11/15 11:14 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I put together a 4.25" stroke 440 recently. I clearanced a fair bit on the oil pickup boss. However, it would of been WAY WAY less possibly none but I only had 1 rod and piston combo back from the machine shop with the block to do the clearance checking, I was way more worried about getting the piston the right way and had the rod in the wrong way for that throw. blush
Re: clearancing 440 block for 4.25 crank [Re: BradH] #1824071
05/11/15 11:16 AM
05/11/15 11:16 AM
BradH Offline
BradH  Offline
bump
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1824243
05/11/15 02:59 PM
05/11/15 02:59 PM
NC
440Jim Offline
440Jim  Offline
NC
Brad,
I never did that combo, but from the other combos (4.25/2.2 and 4.15/2.375) I would think there would be no clearancing for steel rods.
Re: clearancing 440 block for 4.25 crank [Re: moparborn] #1824295
05/11/15 04:02 PM
05/11/15 04:02 PM
AndyF Offline
AndyF  Offline
A 4.15 with 2.20 journals should clear just fine. Not a lot of those cranks around, for some reason the 4.15 cranks usually came with the larger Mopar journals.
I do have a 4.15 with 2.20 crank in my World block with Oliver I beam rods. The Oliver rods are very compact so there is a ton of clearance.
Re: clearancing 440 block for 4.25 crank [Re: AndyF] #1824316
05/11/15 04:23 PM
05/11/15 04:23 PM
BradH Offline
BradH  Offline
Scat offered an RB 4.15" x 2.20" that has since been replaced by a 4.25" version, but I know where one of the original 4.15" cranks is. Molnar currently lists an RB 4.15" x 2.20", too, and it's a 6-bolt (no need to change flexplate, either).
At least one (possibly both) of those companies has 6.76" x 2.20" h-beam rods, and there are plenty of piston choices for that stroke combination w/o having to go custom.
On paper that seemed like a pretty straight forward way to build a machined RB 4.375" bore block into a 499. Not that I NEED another 48 cubes, and already have all the parts on hand (Eagle crank, K1 rods, bearings, CP pistons) for the 451 it was intended to be. shruggy
EDIT: My apology to the OP for semi-high-jacking this thread.
Re: clearancing 440 block for 4.25 crank [Re: BradH] #1825451
05/13/15 01:41 AM
05/13/15 01:41 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Took off around .060 of iron off the the oil pick up boss. Now I have around .080 clearance between the 2.20 Chevy rod and the block
Re: clearancing 440 block for 4.25 crank [Re: 440Jim] #1825581
05/13/15 10:22 AM
05/13/15 10:22 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I ha to clear some on the pic up tube to !
