Intermediate shaft movement? #1822957
05/09/15 09:23 PM
05/09/15 09:23 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
When using a spacer or a set screw collar to limit Intermediate shaft movement, I would think one would want some clearance. Who has done this and what kind of clearance did you end up with using? ( By clearance I mean the shaft can move up a little like .020 or something????????)
Re: Intermediate shaft movement? [Re: fuseable] #1822979
05/09/15 09:55 PM
05/09/15 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I do it I put the collar on it just snug so it can just
move... then I put it in and clamp it down(the dist hold down)
then pull the dist out and measure the collar to the end of
the shaft.. move the collar so I have .015 clearance.. tighten
the collar and put the dist back in and set the timing
wave
Re: Intermediate shaft movement? [Re: MR_P_BODY] #1823921
05/11/15 01:25 AM
05/11/15 01:25 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mike where can I get a collar? I timed the Dart Friday and noticed a small amount of spark scatter...I'd like to see if I can eliminate it... thumbs
...FAFO...
Re: Intermediate shaft movement? [Re: skicker] #1823923
05/11/15 01:30 AM
05/11/15 01:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You might try the hardware store... or Graingers
wave
Re: Intermediate shaft movement? [Re: fuseable] #1824165
05/11/15 02:14 PM
05/11/15 02:14 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I used a old dist/bushing and tapped it for a set screw and Loctite
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Intermediate shaft movement? [Re: fuseable] #1824241
05/11/15 03:58 PM
05/11/15 03:58 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Re: Intermediate shaft movement? [Re: markz528] #1824672
05/12/15 12:09 AM
05/12/15 12:09 AM
BigFish69 Offline
BigFish69  Offline
Tractor supply
Re: Intermediate shaft movement? [Re: BigFish69] #1824856
05/12/15 12:01 PM
05/12/15 12:01 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
does the collar go on the distributor shaft?and whats the procedure for properly installing it?is the collar eliminating most of the upward movement of the intermediate shaft and distributor shaft?and what are the benefits of the collar?sorry d just curious on this post is all.thanks
Re: Intermediate shaft movement? [Re: hp340nos] #1824863
05/12/15 12:10 PM
05/12/15 12:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As the intermediate shaft lifts up(due to the angle on the gear) it
rotates and turns the dist shaft.. in turn changes the timing.. when
you put the collar on it you basically lift the dist shaft and clamp
it tight.. this eliminates the intermediate shaft from lifting and
turning the dist
EDIT
just a little info
as the engine is accelerating the intermediate shaft is pulled
down and you wont get the timing variation.. once its done
accelerating then the load is taken off the intermediate shaft
and will lift... same on decel.. the valve springs kick the cam
back and forth which jumps the shaft up and down changing the
timing
wave
Re: Intermediate shaft movement? [Re: MR_P_BODY] #1824910
05/12/15 01:25 PM
05/12/15 01:25 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
whats the proper way to install the collar then?
Re: Intermediate shaft movement? [Re: hp340nos] #1824918
05/12/15 01:34 PM
05/12/15 01:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Read this post.. I wrote how I do it
wave
Re: Intermediate shaft movement? [Re: MR_P_BODY] #1824951
05/12/15 02:07 PM
05/12/15 02:07 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
ok mike just read the upper post.so it goes on the lower part of the distributor shaft.lightly snug collar, tighten dist down,pull out,add.015 to dim.and thats it?
Re: Intermediate shaft movement? [Re: hp340nos] #1824961
05/12/15 02:28 PM
05/12/15 02:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You got it.. just that simple
wave
Re: Intermediate shaft movement? [Re: MR_P_BODY] #1824962
05/12/15 02:29 PM
05/12/15 02:29 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Anybody got a part number for the collar? I'm not much for 'pokin and hopin' if I can help it.
WIZE
In Car:
Re: Intermediate shaft movement? [Re: Streetwize] #1824963
05/12/15 02:34 PM
05/12/15 02:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry.. no I dont.. never thought about writing the number down
I just get the 1/2" ID one.. then touch the faces on the belt
sander the shaft is just under 1/2" OD
wave
Re: Intermediate shaft movement? [Re: fuseable] #1824970
05/12/15 02:44 PM
05/12/15 02:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ace Hardware stores and tractor supply stores in my area stock them
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Intermediate shaft movement? [Re: pittsburghracer] #1824984
05/12/15 02:56 PM
05/12/15 02:56 PM
California
mickm Offline
mickm  Offline
California
i just saw this post after i posted in the general section. same issue. i'm putting together a prestolite dual point, and have .053 up and down movement. i could look for a locking collar, but what about just finding another washer to put between the collar and the existing washer?
Re: Intermediate shaft movement? [Re: fuseable] #1824989
05/12/15 03:05 PM
05/12/15 03:05 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
You can get the collar from Tractor Supply for like $1.50. Or you can pay for a "specific" Mopar shaft collar off ebay for $16.88, lol.
http://www.ebay.com/itm/Mopar-Distributo...tr#ht_792wt_867
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Intermediate shaft movement? [Re: mickm] #1824994
05/12/15 03:09 PM
05/12/15 03:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The problem is that the end of the distributor doesn't bottom out in the intermediate shaft slot. The intermediate shaft can still move up and down due to the clearance between the two parts. The shaft collar fixes that.
Re: Intermediate shaft movement? [Re: MR_P_BODY] #1825000
05/12/15 03:15 PM
05/12/15 03:15 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
