E body steering column question #182397
01/03/09 11:45 AM
01/03/09 11:45 AM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
Does the column need to come completely apart to replace the turn signal lever?
How about the ignition key cylinder?
Thanks.
Re: E body steering column question [Re: KillerBee] #182398
01/03/09 04:33 PM
01/03/09 04:33 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
The turn signal lever requires removing the crush can only. Picture below.
The key cylinder requires removing the next collar or the turn signal lever housing.
To have access to the key cylinder you will have to remove the lock wheel and then
the plate that hides the access hole to remove the cylinder itself. Next
Jules
Re: E body steering column question [Re: JulesdaWiperman] #182399
01/03/09 04:34 PM
01/03/09 04:34 PM
super gas
super gas
Lock plate.
Re: E body steering column question [Re: JulesdaWiperman] #182400
01/03/09 04:36 PM
01/03/09 04:36 PM
super gas
super gas
Finally take this off.
Re: E body steering column question [Re: JulesdaWiperman] #182401
01/03/09 07:26 PM
01/03/09 07:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You may find the pages / images at this link usefull as well;
http://www.hamtramck-historical.com/ServiceHighlights/1970PassengerCarHighlights11.shtml
Re: E body steering column question [Re: Alaskan_TA] #182402
01/03/09 07:45 PM
01/03/09 07:45 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
65 Barracuda
70 Challenger
Re: E body steering column question [Re: jrwoodjoe] #182403
01/03/09 08:35 PM
01/03/09 08:35 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks guys, excellent information as usual
Re: E body steering column question [Re: KillerBee] #182404
02/08/09 05:29 AM
02/08/09 05:29 AM
Poland
BartekP Offline
BartekP  Offline
Poland
Hi
How to mount steering column in 70 Challenger?
I did it using two pin bolts to dash/pedal frame, and using three bolts to firewall.
But I have also three white rectangular plastic shims, where do these go?
any pictures would be great
'70 Challenger SE '77 Dodge M880/W200 '08 Magnum R/T
Re: E body steering column question [Re: BartekP] #182405
02/08/09 09:55 AM
02/08/09 09:55 AM
super gas
super gas
There are no white plastic shims on an e body column.
They are used in b body applications.
Jules
Re: E body steering column question [Re: JulesdaWiperman] #182406
02/08/09 12:01 PM
02/08/09 12:01 PM
None
71rm23 Offline
71rm23  Offline
None
Not trying to rob the post. Is this the same as the '71 B-Body, without tilt? Where can one get the ignition switch and any other parts?
Re: E body steering column question [Re: 71rm23] #182407
02/08/09 12:07 PM
02/08/09 12:07 PM
super gas
super gas
The ignition switch and the cylinder for that matter are still available form auto parts stores.
Jules
Re: E body steering column question [Re: JulesdaWiperman] #182408
02/08/09 07:15 PM
02/08/09 07:15 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Jules
Still available from Mopar as well.
Craig
