Re: Fuel Pressure Regulator [Re: Jeepmon] #1824193
05/11/15 02:54 PM
05/11/15 02:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well then he is golden there to since a BG400 uses a pump bypass as well.
In the context it is being referred to hear they are talking about return style system after the regulated fuel to the carbs, not at the pump or unregulated fuel. My comments are toward the system being discussed. Don't believe in return systems from the carbs back, bypass at the pump yes.
Re: Fuel Pressure Regulator [Re: Thumperdart] #1824206
05/11/15 03:09 PM
05/11/15 03:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By Thumperdart
Originally Posted By Al_Alguire
He is making just shy of 1000hp. The -8's are what the carb builder wants for this application. Don't really wanna get into the pressure, volume debate but suffice it to say -8 is what needs to be there.
We run an EFI750 pump dead headed to the regulator with just a bypass for the pump with no issues. MagnaFuel sold us the system just this way.
Then it's not truly deadheaded if it bypasses at the pump now is it.
That's true, but most consider a return system one that returns to tank from the reg. My wife's 79 300 (stock fuel system ) actually has a return line off the fuel filter ( after the mechanical pump ). I think the return fitting off the filter has a .060" orifice in it. Pretty sure they ( Chrysler ) were trying to address vapor lock issues.
Fastest 300
Re: Fuel Pressure Regulator [Re: Jeepmon] #1824211
05/11/15 03:14 PM
05/11/15 03:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Unless we are discussing nitrous engines I believe return style systems as referred to here are not necessary. In a nitrous deal I can see it being used to prevent any aeration in the lines to the nitrous solenoids but also seen many many of those guys who do not bother then either. Those systems are similar to what Crizila described and are to bleed air through small orifice lines at the regulators.
Re: Fuel Pressure Regulator [Re: Al_Alguire] #1824220
05/11/15 03:24 PM
05/11/15 03:24 PM
Az
Crizila Offline
Crizila  Offline
Az
I had my fuel system designed by Magnafuel for a 700 HP blown application. They wanted a -10 return line from the reg. ( -8 to the reg. ) My system is all Magnafuel - filters, fittings, pump, reg.
Fastest 300
Re: Fuel Pressure Regulator [Re: Jeepmon] #1824225
05/11/15 03:28 PM
05/11/15 03:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
AS our both of ours. No return, both dead head regulators and the bypass at the pump. 1100 and 1300hp
Re: Fuel Pressure Regulator [Re: Al_Alguire] #1824228
05/11/15 03:31 PM
05/11/15 03:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The direct pump bypass systems are on lots of fast cars but so are deadhead systems but my experience with the Aeromotive hot rod pump when bypassed was no volume left to feed my motor. You could hear the motor struggling to make power on the second half of the track even though the company said it was fine but it wasn't and the Magnafuel 300 system totally rocks and drives fine for long trips on the street.
