Page 3 of 3 1 2 3
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1822790
05/09/15 05:05 PM
05/09/15 05:05 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I believe the 8.75 to be a mistake in that aplication. If you go with a 9" stock will likely fail as well. So a 60 in my opinion would make sense. But I say this about all DT components "nothing too strong ever broke but nothing too heavy ever wins".
Re: which is better and cheeper 8 3/4 or 9 inch [Re: MR_P_BODY] #1822791
05/09/15 05:05 PM
05/09/15 05:05 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By MR_P_BODY
Tony you try to lump everything into one group.. my 8 3/4
with 14" slicks is still running strong... thats with a 1.19
60'
wave
Yes, but your car is a fly weight and you have an aluminum center section. How long would it last in a 3300# big tire, big torque stick car?
It's still running strong? When was that last time that care made a pass?
This has been beat to death, application, application, application..........
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1822808
05/09/15 05:27 PM
05/09/15 05:27 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
1964----SAE engineers put them through acid test 9" good to 450 hp 8.75 good to 500hp....1970 the aftermarket chases the 9 every ratio imagined is produced people find a BUILT 9 is stronger than a stock 8.75----well that is mysterious---if we go with the aftermarket fervor i am thinking all you race boys should go with a small block chevy---aftermarket gives it a big yes---must mean it is the best---back on the 9 its main weakness is the pinion placement at the bottom of the ring gear--they havent changed that---they just piled on more icing on the cake---$ for $ you are money/hp ahead with a dana 60--its pinion placement is almost perfect....next cuda i build i think i will go sbc--powerglide--9 inch and mustang ll brakes and i will paint it hugger orange--- there i covered all the bases with the popular aftermarket taste....it should make everybody happy...
Re: which is better and cheeper 8 3/4 or 9 inch [Re: justinp61] #1822820
05/09/15 05:40 PM
05/09/15 05:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
60'
wave
Its been 2 years now that I havent had my license... and yes
it is light.. and yes its a alum center.. the previous center
which was stone stock with a 4.88 gear lasted 600+ passes and
that was 1.26 60'... its whole life has been with a trans brake
launch... no I would use it in a stick or a heavy car.. weight I
still think is what kills them.. heavy gives more bite till the
tires break free.. if they dont break free then it applies to load
to the gears
wave
Re: which is better and cheeper 8 3/4 or 9 inch [Re: MR_P_BODY] #1822870
05/09/15 07:16 PM
05/09/15 07:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
60'
wave
come on Mike we have had this conversation before, that is not a good comparison. the weight difference and you are not running a factory case so why even bring it up?
Re: which is better and cheeper 8 3/4 or 9 inch [Re: Quicktree] #1822871
05/09/15 07:20 PM
05/09/15 07:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
60'
wave
Because Tony... you have ONE answer for all conditions.. you
dont even ask a couple of simple questions... you dont like the
8 3/4... thats fine.. but dont just say NO.. get the facts first
wave
Re: which is better and cheeper 8 3/4 or 9 inch [Re: MR_P_BODY] #1822874
05/09/15 07:22 PM
05/09/15 07:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
this is fact and it's all one needs to know, if you have a RACE CAR don't waste your money on an 8 3/4
Re: which is better and cheeper 8 3/4 or 9 inch [Re: Quicktree] #1822876
05/09/15 07:28 PM
05/09/15 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BS Tony.. thats just your closed mind.. if he had a 1600# dragster
it would live a long life.. but you dont care about facts... so I'm
gonna drop it right now.. you can have you last say just because
thats you
wave
Re: which is better and cheeper 8 3/4 or 9 inch [Re: MR_P_BODY] #1822901
05/09/15 07:52 PM
05/09/15 07:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thank you very much laugh2
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1822931
05/09/15 08:39 PM
05/09/15 08:39 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Wafflebatter runs a braced 8 3/4 in his roadster. It's braced and the car weighs 1900# race ready. I have a friend with a 2900 Roadrunner that has had a 8 3/4 in it for more passes than about half the people on this site combined. But.....if you are starting from scratch anyway and you are running a gear set available for a Dana. You should consider it IMHO. The Arrow has one and it's the only part I haven't broken yet knock wood lol
5.53 @ 125 1/8th on the launch control..more left in her!
Page 3 of 3 1 2 3
