Can the studs that hold the scoop to the hood-looks like a wood screw on one end, a regular bolt on the other, be purchased in a hardware store. I've checked the big box places w/ no luck. I've gone on-line, but I've got issues w/ spending $65 for the hardware.
Is there an alternative to attching the scoops & not use the factory hardware?
Another possibility. I'm missing four attaching studs-one of the big ones for the back of the scoop, 3 smaller ones from the front/sides. Are these enough to hold the scoops on & keep them from flying off? In my mind, they should hold on; they're not tall enough to catch air (correct?). But, these scoops are almost impossible to find in any condition. Don't want to run the risk of a scoop flying off.
