Painting dash in '89 d100 #1821784
05/08/15 01:00 PM
05/08/15 01:00 PM
Tipp City, Ohio
Backfire Offline OP
Backfire  Offline OP
Tipp City, Ohio
Any special type of paint needed to paint the hard dash pad or will Rustoleum be OK .
Re: Painting dash in '89 d100 [Re: Backfire] #1821828
05/08/15 01:58 PM
05/08/15 01:58 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Rustoleum makes a rattle can formula that works on plastic, metal and wood. I think I have a can or two in my shop...I just have to find it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Painting dash in '89 d100 [Re: Polarapete] #1822009
05/08/15 06:46 PM
05/08/15 06:46 PM
scratchnfotraction Offline
I did the dash and door panels in my truck. clean/scuffed mine and shot it with some 2k primer then paint/clear with some paint I had left over from another fender repair.
only issue I have is the gloss coat blinds you in the sun light when just right on the top of dash.
I am going to scuff it and shot it with a dull coat on the top 1/2 or flat black with dull coat.
turned out good and holds up well so far. I post a pic later.
