NHRA shoulder belt mounting, wrap around okay #1820706
05/07/15 12:02 AM
05/07/15 12:02 AM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Not sure if the NHRA approves of wrap around for the shoulder belts, see picture attached. If need be I will weld tabs to the cross bar and bolt them in, but hate to weld in a done interior.
Re: NHRA shoulder belt mounting, wrap around okay [Re: sawdust] #1820709
05/07/15 12:07 AM
05/07/15 12:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Wrap around is legal ... thats what I do also
wave
Re: NHRA shoulder belt mounting, wrap around okay [Re: sawdust] #1820813
05/07/15 02:04 AM
05/07/15 02:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Need something to keep belts from sliding. Most have a
metal "hoop" welded on the bar for that purpose.
Re: NHRA shoulder belt mounting, wrap around okay [Re: sawdust] #1820817
05/07/15 02:06 AM
05/07/15 02:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
There's also a prescribed way to route the belt through the metal adjuster....
Re: NHRA shoulder belt mounting, wrap around okay [Re: J_BODY] #1820961
05/07/15 11:42 AM
05/07/15 11:42 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Yep, before I welded the hoops on back of the bar, the belts would slide off my shoulders. A tech once told me I could use two hose clamps on the back bar to position straps but there are cleaner ways. Also, I run the strap opposite yours so the loose end of strap comes out underneath the buckle and drops to the floor behind the seat twocents thumbs
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: NHRA shoulder belt mounting, wrap around okay [Re: sawdust] #1820963
05/07/15 11:47 AM
05/07/15 11:47 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.schroth.com/installation-instructions/en/05_restraint_installation.htm
on the bracket you could fab something up on the bench and use a "split collar" type mount and bolt it to the bar... something like the "grab handle" shown in this link...
http://www.fourtreks.com/roll_bar.html
Re: NHRA shoulder belt mounting, wrap around okay [Re: J_BODY] #1821844
05/08/15 02:24 PM
05/08/15 02:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Oh, I like these a LOT: http://www.fourtreks.com/modular_clamp_rings.html
When I talked w/ a local race car supplier about replacing my expired belt, they suggested a wrap-around style, but I balked 'cuz I have a tab mounted on my 'bar and wanted to still use that.
However, I think the wrap-around style secured w/ those clamp rings might be an improvement, since it would allow me to better position how the rear straps come around from the back of my OEM E-body high-back bucket seat.
Thanks for the link! up
