Let's talk paint #1819686
05/05/15 10:08 PM
05/05/15 10:08 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Question about base coat with clear coat. Looking at a car that has orange peel in the paint. Is the orange peel in the base coat...or the clear coat ??
Can it be sanded out to eliminate the orange peel ?
Thanks in advance....Thanks MOPARTS
Re: Let's talk paint [Re: terzmo] #1819711
05/05/15 10:38 PM
05/05/15 10:38 PM
USA
hudsonhornet7x Offline
USA
Probably a little bit of both, but if there is enough clearcoat on the surface it can be wetsanded and polished to a mirror shine.
Are we talking new cars, one you have painted, or an old car you bought with paint like this?
Re: Let's talk paint [Re: terzmo] #1819714
05/05/15 10:40 PM
05/05/15 10:40 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
this is a extremely vague question.
it can be in both the base and the clear. it could also be in the sealer coat also.
it's most likely in all 3.
it depends how much clear is on the car to sand it out. you need at least 2 mils of clear for long term durability. chances are there won't be enough clear left after sanding and buffing.
if the peel is in the base the color can look odd with smooth clear over rough base.
perception is 90% of reality
Re: Let's talk paint [Re: terzmo] #1820118
05/06/15 11:48 AM
05/06/15 11:48 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
If it has clear, the orange peel you see is the clear. Yes it can be wetsanded and buffed to get it smooth. I wouldn't use anything more course than 1500.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
