Re: out with old headers welding new,pics
[Re: Clanton]
#1385283
05/15/13 11:19 AM
05/15/13 11:19 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
My hat's off to you for the effort, looks like alot of work.
Rich H.
Esse Quam Videri
[Re: Cheatham]
#1385289
05/16/13 11:16 AM
05/16/13 11:16 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
That is a nice job on them headers
My uncle lived in Texas "Marshal Clanton"
[Re: Clanton]
#1385296
03/12/14 06:36 PM
03/12/14 06:36 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I definitely would not do the square pattern, it would look unfinished like you forgot to install the collector or something.
Since the car has a blower you could get away with the flat pattern zoomies but you will never be able to put mufflers on it in the future, so as long as you're ok with that you should be fine.
[Re: ProSport]
#1385297
03/12/14 06:47 PM
03/12/14 06:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yep ... if its a street car... thats gonna be hard for exhaust
[Re: MR_P_BODY]
#1385298
03/12/14 07:31 PM
03/12/14 07:31 PM
Clanton
northern,Ohio,USA
The pipes seperate/slip on at the fender so I just remove one and replace it with the other with a collector end that I have to redo so a muffler can fit.I need to run a strap on the pipes to hold them togather on the lower part and support them also.Any ideas?
[Re: Clanton]
#1385299
03/12/14 07:58 PM
03/12/14 07:58 PM
MR_P_BODY
If you can weld a strap across the 4 tubes then attach a hanger at that point... then when you change to a collector you might be a bile to attach at that same point with the hanger... I use a certain style of hanger with a rod and rubber block.. this has more fore and aft movement than sideways which all exhaust grown in length... of course you have to mount it in the direction of growth... this one isnt attached at this time to the pipe
