SB head gaskets with boost #1819401
05/05/15 03:39 PM
05/05/15 03:39 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
school me on head gaskets for a boosted small block.. i know our head bolt design is about identical to sbf with 10 studs and those guys are using the felpro mls or the cometic mls with no issues.. what do you guys think? i know there isnt much of us out there..
Re: SB head gaskets with boost [Re: rgreule] #1819467
05/05/15 04:52 PM
05/05/15 04:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself.. I would go with Cometics on a boosted set up
wave
Re: SB head gaskets with boost [Re: rgreule] #1819500
05/05/15 05:47 PM
05/05/15 05:47 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
that is what im leaning towards. was also interested in cometic vs copper gasket or o-ringing it.. i just wasnt sure.
Re: SB head gaskets with boost [Re: rgreule] #1819529
05/05/15 06:38 PM
05/05/15 06:38 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
i use cometics and have used them for years with no issue
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: SB head gaskets with boost [Re: rgreule] #1819544
05/05/15 07:04 PM
05/05/15 07:04 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
what kind of boost numbers have you pushed? also what kind of power was it making?
im looking to run 25+ and make 1200whp give or take
Re: SB head gaskets with boost [Re: rgreule] #1819553
05/05/15 07:20 PM
05/05/15 07:20 PM
dogdays Offline
dogdays  Offline
Good luck with that! Although boosted engines seem to tolerate more horsepower than N/A ones.
Be sure to finish the head and deck to whatever Cometic wants.
R.
Re: SB head gaskets with boost [Re: rgreule] #1819656
05/05/15 09:35 PM
05/05/15 09:35 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Cometics here 11.5:1 and 10 lbs 650ishwhp.
I'd almost look into getting your block and heads o ringed for that kinda power.
Love the car btw.
Re: SB head gaskets with boost [Re: MR_P_BODY] #1819670
05/05/15 09:54 PM
05/05/15 09:54 PM
Az
Crizila Offline
Crizila  Offline
Az
wave
up A little pricey, but that's what I run. 21 PSI through the lights and no problems. Also run studs with 105 lbs. torque.
Fastest 300
Re: SB head gaskets with boost [Re: rgreule] #1819855
05/06/15 12:33 AM
05/06/15 12:33 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Cosmetics for me. Mine at 9:1 non intercooled factory head, was run at 20psi. Just a touch of visual issues, but never leaked.
I'm sure with a better head/tuneup they'd hold even more.
