I need a Hemi valve adjuster nut and cant find one #1818832
05/04/15 09:15 PM
05/04/15 09:15 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
For the Dick Landy Gen 2 Hemi roller rockers....I need 1 valve adjuster nut....and can't find a similar nut anywhere....Help!?!?
Rick
901 399-0245
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1818926
05/04/15 11:06 PM
05/04/15 11:06 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Do you have a pic of one? That might help you find one. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: I need a Hemi valve adjuster nut and cant find one [Re: astjp2] #1819083
05/05/15 01:16 AM
05/05/15 01:16 AM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
A 9/16 wrench fits it, it's 24 threads per inch and the adjuster hole is 3/8's, and the nut is only 3/16th's thick. It's hardened and black.
Unfortunately ATM my computer wont get pic off my camera....
Take care,
Rick
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1819096
05/05/15 01:25 AM
05/05/15 01:25 AM
USA
B3RE Offline
B3RE  Offline
USA
Check out this link. These aren't blackened, which is only a surface finish, but this is what you need. Maybe you can find something blackened from another source.
http://www.grainger.com/product/GRAINGER-APPROVED-Hex-Jam-Nut-1JY65
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1819114
05/05/15 01:49 AM
05/05/15 01:49 AM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Take care,
Rick
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1819278
05/05/15 12:35 PM
05/05/15 12:35 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Originally Posted By HemiRick
Or these. This style has more contact area under the nut.
http://www.amazon.com/ARP-3008391-8-24-Point-Nut/dp/B001O060WM
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1819281
05/05/15 12:38 PM
05/05/15 12:38 PM
USA
B3RE Offline
B3RE  Offline
USA
Looks like a winner! I was thinking after my previous post, that type of nut is what Crane, ProForm, and the RAS rockers I have use as well. Just a thought.
Mike Beachel
Re: I need a Hemi valve adjuster nut and cant find one [Re: DusterDave] #1819284
05/05/15 12:43 PM
05/05/15 12:43 PM
USA
B3RE Offline
B3RE  Offline
USA
They both have a nice flat surface on the bottom, but are quite a bit taller, and heavier, which adds a lot of weight to the adjuster side of the rocker. I got some of the 12pt ones for my RAS rockers, but changed them back because of the lower weight.
Mike Beachel
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1819286
05/05/15 12:45 PM
05/05/15 12:45 PM
Northern MN
cedarmachine Offline
Northern MN
I use the same ARP nut except the 12 point head. They give you a little more latitude with the box end wrench
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1819355
05/05/15 02:43 PM
05/05/15 02:43 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
If the replacement nuts are thicker I figure I can grind them thinner.
Take care,
Rick
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1820274
05/06/15 03:29 PM
05/06/15 03:29 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
PM sent
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: I need a Hemi valve adjuster nut and cant find one [Re: HemiRick] #1821067
05/07/15 02:29 PM
05/07/15 02:29 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
The new nuts arrived and they are standard thickness. I ground one as thin as I dare and it now weighs 5.7 grams and the original was 4.6 So I fixed it but gained 1.1 grams.
Take care,
Rick
