Hardened Valve Seats
#1818882
05/04/15 10:10 PM
05/04/15 10:10 PM
Posts: 4,293 Morrow, OH
markz528
Morrow, OH
For a stock 383, is it necessary to put hardened valve seats on the intakes, just the exhaust or both?
Re: Hardened Valve Seats
[Re: markz528]
#1819466
05/05/15 04:47 PM
05/05/15 04:47 PM
Posts: 5,169 CT
GTX MATT
CT
Since you've gotten no replies, I'll bite. Intake no. Exhaust is debatable and may depend on intended usage. I know of some very knowledgeable/reputable guys who say you don't need it, especially for an engine that won't see too many miles.
I have torn down a 300K mile 383 with 906 heads which had been running on unleaded for the past 25 or so years. It has some noticeable valve depression on 2 or 3 exhaust valves. Not sure if lead additive was used often, but I know it wasn't always used. 300K on a set of heads isn't too shabby.
Whats the background on the situation/what is the engine for?
452 and later heads came with hardened exhaust seats.
[Re: markz528]
#1819471
05/05/15 05:01 PM
05/05/15 05:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I do know that cast iron now days is much harder than it was years ago(easy to spot by the ring ridge in the bores).. in the old engines that I tested back in high school both valve would sink.. the exhaust would go about double the intake.. but if this is just a week end ride I wouldnt worry a ton about either.. but if you plan on decent mileage I would do the exhaust seat EDIT I wish I could remember when they changed the nickle content in the iron so I could give you a better answer
[Re: MR_P_BODY]
#1819517
05/05/15 06:20 PM
05/05/15 06:20 PM
markz528
Morrow, OH
Thanks for the responses.
This is my anal restoration car. Wont see a lot of miles. Engine builder says to do the exhaust but not the intakes.
Don't know if I should overrule him and spend the extra $200 to get the intakes done too.
[Re: markz528]
#1819586
05/05/15 08:00 PM
05/05/15 08:00 PM
Posts: 452 new york usa
pattyboy 572
new york usa
Wouldn't installing stainless steel valves eliminate that issue. ?
[Re: markz528]
#1820204
05/06/15 01:20 PM
05/06/15 01:20 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Put them on the exhaust only. Seen enough of them w/ valves sunk really far into the head that I'd never run a set w/o hardened exhaust seats.
