LA 360, only afford one, which Headers or Carb/intake?
#1818859
05/04/15 09:52 PM
05/04/15 09:52 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
I was searching the PickAPart and saw a '72 Dodge Van with Headers and a Factory 2bbl carb and intake. Had me wondering, if you could only afford one or the other, which would you spend your money on, headers or a 4bbl intake and carb?
Which would better improve performance?
Ideally, you up compression, better cam/lifters, better heads, 4bbl intake/carb and headers/larger pipes/mufflers, but if only one improvement, headers or intake/carb?
Re: LA 360, only afford one, which Headers or Carb/intake?
[Re: D_C]
#1818884
05/04/15 10:12 PM
05/04/15 10:12 PM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you can scrounge a factory 4bbl intake and carb on the cheap, then buy the headers. If the car has single exhaust, I would fix that problem first over the 4bbl.
[Re: gregsdart]
#1819134
05/05/15 03:05 AM
05/05/15 03:05 AM
D_C
Thanks for the replies.
The vehicle, is a '74, has 2 1/2 inch Dual exhaust (non-mandrel bent, no H or X pipe) with 4.10 gear limited-slip differential, factory C.I. intake and Holley 2bbl and factory cam.
I grabbed the "Van" headers for $40.
[Re: D_C]
#1819217
05/05/15 10:44 AM
05/05/15 10:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I grabbed the "Van" headers for $40. Being that you have a 4.10 gear (I assumed it was a stock type car) the carb and intake would be my next choice.. the exhaust on the car is decent but not set up for high rpm
