Re: In car Hemi valve spring compressor
[Re: EDG]
#2199212
11/20/16 01:03 AM
11/20/16 01:03 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I am in need of one also. Please PM me if you want to try to get the multi purchase discount I was wondering if you still have pictures and if the phone number is good. I'm looking for a head on valve spring compressor for a 428 Hemi. Thanks for any help. Contact Ed at hemirr69@gmail.com
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: CCG]
#2199284
11/20/16 10:07 AM
11/20/16 10:07 AM
Posts: 7 IL
EDG
IL
I'm looking at the valve spring compressor made by Richard Troutt. I like the two position handle, I think that's the way its made? How hard is it for one guy to use? I'm an old man,but I can still power shift,anyway is his number still good . I would rather have the Mancini style one if anyone got one to sell. I'm replacing valve seals. I think by now after searching for a spring compressor I could of just pulled the heads and been done. Thanks for any info. Ed Also do you have to remove the rocker arms to use RT style? Thanks again
[Re: EDG]
#2199319
11/20/16 12:11 PM
11/20/16 12:11 PM
Posts: 1,466 malvern, ohio
3ddart
malvern, ohio
Not sure it will work for you but check amazon for a compressor made for a pinto (ford) motor. That is what I have used, but I'm running a hydraulic roller so spring pressure is not real high. I just looked and it is listed under "sealed valve spring compressor "
can 13
[Re: SNK-EYZ]
#2199439
11/20/16 04:52 PM
11/20/16 04:52 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
The tools with the hook require you to remove the rockers,,,,,,
[Re: SNK-EYZ]
#2211773
12/11/16 12:52 PM
12/11/16 12:52 PM
CrazyD
