In car Hemi valve spring compressor
#1655209
08/05/14 02:34 AM
08/05/14 02:34 AM
Posts: 10,144 A Red State
SNK-EYZ
A Red State
Does anyone know a source to get one of the in car 426 Hemi valve spring compressor like this? Mancini says they're not made anymore. Tried contacting Detroit Tool and they don't respond at all. Does anyone know of where I can get one or something that's similar? I need to do a valve spring swap in the car. How hard is it to swap the springs with the prybar type of tool like this?
Re: In car Hemi valve spring compressor
[Re: SNK-EYZ]
#1655210
08/05/14 06:35 AM
08/05/14 06:35 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I can try and contact the guy that was making them for Mancini. He may still have a few. I'll let you know.
JAKES AUTOMOTIVE
[Re: JAKE68]
#1655211
08/05/14 11:57 AM
08/05/14 11:57 AM
Posts: 2,658 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have a Ray Barton but I have never used it so I can't comment but you can try him. Mazzolini would probably know how also.
2011 Drag Pak Challenger
[Re: rickseeman]
#1655212
08/05/14 12:03 PM
08/05/14 12:03 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Made my own,piston on TDC, 100 psi in the hole and it's a pain in the............
[Re: SNK-EYZ]
#1655215
08/05/14 03:48 PM
08/05/14 03:48 PM
Posts: 361 Canada
onig
Canada
Not sure if this will help you. I made a tool that goes over the rocker shaft to do this on a small block. It works very good and easy. We had a little over 600 pound spring in there. If I needed more leverage I just use a longer tube or pipe. I made a short shaft to bolt down and the compressor slid over the shaft. Moved it from cylinder to cylinder. Found that if the piston was on TDC that the air pressure would push the piston down, no problem, just keep the air in there until done. How much spring pressure do you have? Hope this helps.
69 Dart
[Re: onig]
#1655216
08/05/14 03:51 PM
08/05/14 03:51 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I have two! Make me an offer for one. This is the one I have that I used in my book. [/URL]
[Re: CCG]
#1819118
05/05/15 02:05 AM
05/05/15 02:05 AM
SNK-EYZ
A Red State
Depending on how soon you actually need it I could loan you mine.
I'm finally going to do the cam swap in my car in the next few weeks so I need it for now. With doing all of Kayse and mines wedding prep (it was a Renaissance Wedding at our house, last Saturday) the cam swap was put off. I'm still taking tents/shelters down, returning folding chairs and tables.
By next week I should hopefully get started on the cam swap.
[Re: CCG]
#1821183
05/07/15 05:36 PM
05/07/15 05:36 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Thanks so much for the offer Sputnik. However I think I am going to buy one that Richard Troutt makes. He said I could put his number here for anyone looking for one and is (765) 673-7514. It is a small very easy to use tool that fits in a tool box. He or I can e mail pictures. It is not shown on any URL's I am aware of. Can you post a picture of it?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
