Good alternator for 440/rpm heads & lots of electric acc
#1818704
05/04/15 07:04 PM
05/04/15 07:04 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Need some suggestions for alternator and brackets. I prefer an externally regulated alternator.
I'll be running an electric fuel pump, electric fans, large stereo. Plus all the accessories and lights that a typical street car uses (all external lights, heater, interior lights) and possibly electric windows/locks in the future.
Its a street car and will be at idle a lot, not sure what I need for a minimum idle amp output.
I looked at the denso 120 kit from mancini, they say its a 3 wire and puts out about 65 at idle.
Mancini didnt think this would be enough for my application, and suggested the powermaster 170amp, #43311, but it will need a v groove pulley installed and they cannot confirm what brackets it's compatible with. The powermaster 43311 is a 3 wire and advertised to put out about 100 amps at idle.
What other options do I have?
Re: Good alternator for 440/rpm heads & lots of electric acc
[Re: AndyF]
#1818747
05/04/15 07:51 PM
05/04/15 07:51 PM
RapidRobert
What Andy said, I've heard good regarding the Denso plus if it's pretty much the only bolt in, I'd pull the trigger on it. Make sure you have a regular (dia) crank pulley 7.25" iirc, not a smaller one. there are 2 diameters of OE alt pulleys, not sure which one the Denso comes with
[Re: Adam71Charger]
#1818787
05/04/15 08:22 PM
05/04/15 08:22 PM
RapidRobert
you might call some of the local stereo shops & the right guy who has dealt with this before from a customer might be able to give you some sound advice on that. EDIT A shop that does actual installations
[Re: Adam71Charger]
#1819610
05/05/15 08:42 PM
05/05/15 08:42 PM
Posts: 7,664 IN
ahy
IN
"Big Case GM" would be the 200 amp version in the link attached (12 SI I believe). The Summit link looks like a newer "custom Chrysler case" style. Spendy but so is the 200 amp Delco derived unit. Another consideration is drive belts. Rule of thumb, one belt is happy up to 100 amps. Sounds like you will need more than that for extended periods so may consider two belts. Also, in non AC applications many have adopted original GM style big case alternators. May be worth getting a JY unit from a big Buick or something like that for test fit. That would be the only low cost option I know of. http://www.powermastermotorsports.com/mopar_high_amp.html
[Re: AndyF]
#1819963
05/06/15 03:27 AM
05/06/15 03:27 AM
Posts: 5,450 So Cal
Sinitro
So Cal
1000W at 12 volts requires 83 amps. But the duty cycle on a stereo amp is pretty low. They usually don't consume anything close to full power. Most guys add a second battery if they're going to run a big amp at max power for more than a few minutes at a time. The current drain can be significant if he is driving some subwoofers and pounding the bass... However the highest current drain of accessories he has mentioned are the cooling fans, some of these can draw up to 75 Amps.. Just my $0.02.. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: Sinitro]
#1819990
05/06/15 08:35 AM
05/06/15 08:35 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
1000W at 12 volts requires 83 amps. But the duty cycle on a stereo amp is pretty low. They usually don't consume anything close to full power. Most guys add a second battery if they're going to run a big amp at max power for more than a few minutes at a time. The current drain can be significant if he is driving some subwoofers and pounding the bass... However the highest current drain of accessories he has mentioned are the cooling fans, some of these can draw up to 75 Amps.. Just my $0.02.. Any car audio guy will tell you that if you are running a big amp, you should be using a capacitor (at least 1 farad) to help lessen the voltage dips on the electrical system from bass notes on the subs. This will keep you from seeing dimmed out lights that follow the music and lessen the load on the alternator. That will help significantly with the low duty cycle loads (like bass notes). ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
