Re: Installed height on Indy heads?
[Re: AndyF]
#1818692
05/04/15 06:49 PM
05/04/15 06:49 PM
Posts: 2,937 A shed in England
Tig
A shed in England
The 600 -13X come with 2.100 but they are only good for a 4.840 bore space. Pretty sure our 572 - 13s came with 2.000 installed height so you could go higher with + locks, IIRC they are a longer valve than the -1 heads. HTH's. Tig ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: AndyF]
#1818861
05/04/15 09:53 PM
05/04/15 09:53 PM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I found some spring cups that were real thin, got to 2.050 on my 528 with 440-1 heads. Can't remember the brand of parts, but most of my stuff is Manley. I believe my Ti retainers are +.100, locks are +.050. The retainers look like they are pulling through! ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) If the valve length and rockers arte the same location as 440-1 heads as cut for Jesel stuff, you might make it. My math says you need at least .020 lash to get there, with a 1.130 coil bind, .060 clearance, and .880 gross lift.
[Re: AndyF]
#1819186
05/05/15 09:38 AM
05/05/15 09:38 AM
gregsdart
Those are the 1.55 rockers, haven't tried the 1.7s yet. I forgot to mention, those springs are Comp triple 947. I figure if I try the 1.70 rockers, I could use a 948 spring on the intake side. A good used set in at 2.050 ought to be plenty of spring.
