Re: How high do you spin your 4.15 or 4.25 RB stroker?
[Re: BradH]
#1818454
05/04/15 01:49 PM
05/04/15 01:49 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
When we ran the B1 all out we shifted it at 8400. I am trying to finish up my 605 and expect to be shifting it around 8200 or so.
[Re: BradH]
#1818466
05/04/15 02:01 PM
05/04/15 02:01 PM
Posts: 43,247 Bend,OR USA
Cab_Burge
My first pump gas stroker motor 512/518 C.I. like to be shifted at or above 7000 to 7300 RPM. That motor made peak HP at 5600 RPM and peak torque at 4500 RPM on the engien dyno At the track it went fastest shifting at or above 7000 RPM, the converter, gear ratio, tire size and all the other variables do come into play
[Re: BradH]
#1818500
05/04/15 02:25 PM
05/04/15 02:25 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
4.15 stroker here. I usually spin it to around 65 at the traps, but have gone to 7 a couple times between shifts, unintentionally...
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: BradH]
#1818510
05/04/15 02:37 PM
05/04/15 02:37 PM
Al_Alguire
Las Vegas
I think ET and HP numbers might play a role here too Small bore hp=RPM!!
[Re: BradH]
#1818841
05/04/15 09:29 PM
05/04/15 09:29 PM
Al_Alguire
Las Vegas
What block are you using to get q 4.600 bore? Assume it is the Indy 4.84" BS deal. Wish there were some decent heads for that block, like maybe a 4.84BS Predator head.
[Re: BradH]
#1819046
05/05/15 12:39 AM
05/05/15 12:39 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Gee, I feel like a small block guy with only a 505 stroked pump gas 440. I shift at 68 and cross the line at 67. It will easily go to 74 but I see no need to go that high.
[Re: BradH]
#1819285
05/05/15 12:45 PM
05/05/15 12:45 PM
Al_Alguire
Las Vegas
So is the block Indy 4.84BS???
[Re: BradH]
#1819325
05/05/15 01:58 PM
05/05/15 01:58 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Not to hijack the thread ......
Question re shift points. My combo E.T.s best when I shift into second at around 5200 (near peak torque) If I raise the shift point the car slows a couple of tenths. The engine dyno`d at peak RPM / HP @ 6900 and is a 557" RBRE Hemi . Running 14.5/32/15`s , `Glide , 4.10 Dana , 5400 stall Neil Chance conv. Anyone? chryco
Again not trying to hijack the thread
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
