46 Plymouth #181828
01/02/09 05:15 PM
01/02/09 05:15 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
I have chance at a 46 Plymouth coupe for cheap I also have a 87 Dakota that isn't going anywhere quick. I looked at using the Dakota front frame on the 46. Are the frames close enough where you could stub them together? I like the idea of disc brakes rack and pinion steering with the old styling of the 46. I would use the 8 1/4 rear out of the Dakota are the widths of the Dakota and the 46 close? I know there's aftermarket stuff out there but it would suit me best to use the free Dakota stuff. Thanks for your help.
Re: 46 Plymouth [Re: moparpollack] #181829
01/02/09 06:27 PM
01/02/09 06:27 PM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
I have a 49 dodge, not sure how much of a difference, but I have a dakota front clip. I got my help from a Tim Adams on the P15 D24 website, do a search there. I had posted here a couple pics of mine. Go for it and good luck
Re: 46 Plymouth [Re: 49wayfarer] #181830
01/02/09 07:44 PM
01/02/09 07:44 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
You can check on
www.jalopyjournal.com on the H.A.M.B.
I think there is a multi page thread about it there
One other option is
www.fatmanfab.com offers parts to lower the front and to adapt disc brakes and I think its Ply-do that has the rack and pinion parts
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 46 Plymouth [Re: 49wayfarer] #181831
01/02/09 07:49 PM
01/02/09 07:49 PM
85086
Lil Herman
Lil Herman
85086
Thanks I looked on the website but didn't see the information. I figured the car would be more popular, guess not. Did you use the Dakota rear when you clipped your car? Could you use the standard steel wheels? Please post a picture of your car. Thanks!
Re: 46 Plymouth [Re: moparpollack] #181832
01/02/09 09:06 PM
01/02/09 09:06 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
http://www.jalopyjournal.com/forum/showthread.php?t=307020&highlight=dakota
The seach function on the hamb works great unlike others
No, I bought from www.jimweimerrodgarage.com
I used the MII from him and the triangualted 4-bar
Depends on the budget , I think its nice clean install when finished and by the time you buy all the parts, pieces for the swap it ends up about the same
Re: 46 Plymouth [Re: bigdad] #181833
01/02/09 09:36 PM
01/02/09 09:36 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
my 48 plymouth was 32 1/2" where it was cut and is 34 1/2" by the fire wall I don't know if that helps
http://i247.photobucket.com/albums/gg121/NoFrillsPlymouth/48003.jpg
Re: 46 Plymouth [Re: bigdad] #181834
01/02/09 09:42 PM
01/02/09 09:42 PM
85086
Lil Herman
Lil Herman
85086
I haven't plunked down the $300 for the car yet. Just getting ideas I have the truck and like the way it drives with the rack and pinion steering. There was a guy in Phoenix who had a 46 and he had bolt on disc brakes since they were twin a arm set up from the factory. The frame is pretty narrow from the factory on the 46 I wonder if a v-8 will be a tight fit. When I buy the car I will post pictures.
I was just jazzed to find a car that was rust free, had good glass, and all the doors opened and closed. I was shocked at the gaps in the doors and the fenders they were as nice as a new car.
On a side note the old man has 28 model A trucks, and a ton of old cars. He had a 27 Chivey coupe that he was working on. He had a brush hog made with a v-8 flathead connected to a 36" saw blade. Needless to say he won't be finishing them all.
Re: 46 Plymouth [Re: moparpollack] #181835
01/02/09 09:52 PM
01/02/09 09:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I had a 39 Plymouth business coupe that had a 1st gen Dakota rear axle under it. it was a very good fit with 15 x 7 wheels. Those were about as wide as a guy would want to go, and that wheel was centered in the fender.
We clipped a 39 sedan with a Dakota clip, it fit real nice frame, matched up perfectly at the firewall. We split the 39 frames "X" member and slid the Dakota inside the 39's frame, but we sold the car before it was road worthy. A 39 has the same frame as up to 49. Have no knowlege about car frames newer then the 48/49 change.
Re: 46 Plymouth [Re: poorboy] #181836
01/02/09 10:03 PM
01/02/09 10:03 PM
85086
Lil Herman
Lil Herman
85086
We clipped a 39 sedan with a Dakota clip, it fit real nice frame, matched up perfectly at the firewall. We split the 39 frames "X" member and slid the Dakota inside the 39's frame, but we sold the car before it was road worthy. A 39 has the same frame as up to 49. Have no knowledge about car frames newer then the 48/49 change.
Sounds great! I'm looking for something easy and the Dakota parts are free. I'm not looking to build a race car just something to cruise.
Re: 46 Plymouth [Re: poorboy] #181837
01/02/09 10:12 PM
01/02/09 10:12 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
$300 is cheap, that way you will be in it right and you can afford to do some stuff to it
You can stick a 318 in there easy, mine had a 440
plenty of room
Seriously, I'd consider putting the bolt on parts on it ..It would be a nice quick option , others have done it and it works well
Re: 46 Plymouth [Re: bigdad] #181838
01/02/09 10:52 PM
01/02/09 10:52 PM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
You have alot of options with that car. There are a couple places that sell disk brake upgrade kits, Fatmans sell R&P stuff along with the brakes. Its a good solid frame and suspension, worst problem is the brakes and the shock mount is on the upper control arm, which can be moved to the frame. Next thing is the engine, if you keep the flathead, most want to go with a T-5 transmission, or bolt on engine mounts for a small block. Only thing with a small block is the steering box, you need that funky exhaust manifold from a 273 that wraps aroung the column. For more info on 318 swap, check out shadowcustoms website, he's posted here and on the HAMB. I went with the Dakota because of the costs of all the bolt on parts, I got my frame from the local pick n pull for under $50. You can use the rear axle too, but I went with a 8 3/4 since I'm putting in a 383. Lots of stuff on early mopars on the HAMB, getting more popular.
Re: 46 Plymouth [Re: 49wayfarer] #181839
01/03/09 02:47 AM
01/03/09 02:47 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
He is correct that you have a lot of options with that car.
We have rolled out of my shop a 39 plymouth coupe with stock frame, disc brake conversion, rack & pinoin steering, and a 3.9 V6 from a Dakota. We put about 8,000 miles on before it went down the road. We did the Dakota clip on the 39 sedan. We did a 360 with headers, 727, a disc brake conversion and an 8 3/4 with the stock frame and suspension in a 47 Plymouth coupe. We did a flathead 6 with OD, stock suspension, drum brakes on a 41 Chrysler sedan. A 35 Dodge sedan with a Volari clip, 318 auto, 8 3/4 we put over 70,000 miles on. We did Dodge trucks too, a 54 with an F,M,& J clip, 360 auto, 8 3/4. a 55 Pannel van with stock suspension with a hot 360 auto, a 50 mounted on an 80 4x4 frame, and currently putting a 77 frame under a 70 short box. Been a few dirt track Mopars thrown in there as well and several Mopar muscle cars. And that's just our stuff, not customers things. A guy can screw up a lot of nice cars in a little under 40 years of building them. Add in a 25 yo son also addicted and the car count jumps again.
After all that, its going to be very hard to beat the price of putting that Dakota under your $300 Plymouth. There is going to be some work that will have to be done, like the Dakota motor will have to be moved towards the rear, several inches to fit in the engine bay. You will also have to modify the Dakota frame in front of the front crossmember and come up with brackets to mount the cars front sheet metal and a radiator. That is all part of the fun. Gene
Re: 46 Plymouth [Re: bigdad] #181840
02/24/09 04:39 PM
02/24/09 04:39 PM
Puyallup, WA
Joe-Bob Offline
Joe-Bob  Offline
Puyallup, WA
Hey bigdad... I'm totally new to message boards, so I'm hoping this winds up in the right place...
I have a little '42 Plymouth business coupe. Bought it 3 or 4 years ago and converted to 12 volts, put shorter coils up front and built some blocks to bring the back-side down. Then I took off the hub-caps and I'm pretending it's a hotrod. No power, the engine is leaking oil, the ride sucks and the brakes are scarry. I bought a little 318 with a 904 and now am contemplating the best options of getting it in and making the car stop. I've been looking at the FatMan stub, but you say you went with the JW Rod Garage setup. Gotta ask why you went that way since you seem to be happy with it. I'm no engineer or fabricator so I'm looking for something pre-engineered with a semi-dummy in mind. I don't want to start something I can't finish. Do you have any pictures of the job when it was finished?
Re: 46 Plymouth [Re: Joe-Bob] #181841
02/24/09 08:48 PM
02/24/09 08:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
welcome aboard, Joe-Bob!
Bigdad should be along shortly.
Do lots of research before choosing any one way to go. It stinks to get half way done and find out that there was a better/easier/cheaper way.
Here is Dakota info
http://66.154.44.164/forum/showthread.php?t=307020&showall=1
Re: 46 Plymouth [Re: RodStRace] #181842
02/24/09 09:10 PM
02/24/09 09:10 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Guess I'm kinda predictable ?
Oh, the fatman stub is a good option , I just created the same thing out of rectangular tubing and saved some money ..
Just depends on ones budget..
Here are a couple (lousy) pics ..
Re: 46 Plymouth [Re: bigdad] #181843
02/24/09 09:12 PM
02/24/09 09:12 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
One of these days I'll uncover a disc that I have with some decent pics of the build
Re: 46 Plymouth [Re: bigdad] #181844
02/24/09 09:13 PM
02/24/09 09:13 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: 46 Plymouth [Re: bigdad] #181845
02/24/09 09:20 PM
02/24/09 09:20 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Since you are located in Pacific NW ..
Contact www.jimmeyerracing.com ..Quality stuff ansk them if there is a shop in area they would recommend to do a IFS swap if thats the way you want to go
Re: 46 Plymouth [Re: bigdad] #181846
02/25/09 12:35 AM
02/25/09 12:35 AM
Puyallup, WA
Joe-Bob Offline
Joe-Bob  Offline
Puyallup, WA
Cool DeSoto bigdad. And nice shop, big and CLEAN. I wasn't aware of Jim Meyer Racing. I might have to look into them as well.
I've got a '52 Chev that I've had for about 15 years. It has a Nova clip that was in it when I got it. Too wide and sits too high. Did a lot of custom body work to it, but never finished and lost interest. I want to be sure that doesn't happen again. I need to keep things simple enough that I can stay focused on one task at a time and keep the car on the road. Whacking the frame off without a kit to put it back together would probably mess me up. Keeping the frame in one piece and adding new components seems more do-able.
Money is always another factor. The FatMan stub will run around $2540.00, I'm not sure how much the JW Rod Garage setup is. Rebuilding the stock front end, installing dropped uprights and adding disc brakes isn't cheap either and it sets the wheels out further also.
I'm looking to collect parts until next fall, and have a winter project. I've got some time to get some feedback from different views, make a decision and move forward slowly.
Thanks for the input.
Re: 46 Plymouth [Re: Joe-Bob] #181847
02/25/09 07:36 PM
02/25/09 07:36 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Car looks cool right now I think !!
As I posted earlier in this thread
using a couple sources, you can ..
Lower the front with parts from www.fatmanfab.com
I used to have a link from www.rodandcustommagazine.com that showed them
Installing the parts, new springs and disc brakes
I believe its Ply Do that sells the rack and pinion steering parts for one
That kit will drop the nose 3 inches If I remember right and then use some blocks in the rear ...
No cutting, should be able to knock it out in a weekend ..
Then swap a V8 in or I've seen some hopped up flathead 6's that look neat too
I used a 8 3/4 rear from a 68 Chrysler Monaco
for my rear diff ..
I agree, keep the project simple enough to see it thru
