Re: Oil pan bolts will not stay tightened
[Re: rck850]
#1817830
05/03/15 05:52 PM
05/03/15 05:52 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I locktite mine and it works GREAT.
[Re: rck850]
#1817866
05/03/15 06:52 PM
05/03/15 06:52 PM
Posts: 740 WA
JD Dart
WA
I've been dealing with this issue for several years now. The 440 in my Duster will not hold torque on the oil pan bolts. The pan is a Milodon, two of the black fiber type gaskets, windage tray, and the bolts are ARP stainless. I have to re-tighten the bolts every few weeks or I get leaks. Is there any way to correct this? Should I try loctite, thread sealant, or just get some regular steel bolts? Thanks I got tired of them doing this to went to studs and used the nuts that have the serrations to keep them locked in place
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: rck850]
#1817881
05/03/15 07:12 PM
05/03/15 07:12 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
[Re: JD Dart]
#1817885
05/03/15 07:17 PM
05/03/15 07:17 PM
Posts: 7,506 Az
Crizila
Az
I've been dealing with this issue for several years now. The 440 in my Duster will not hold torque on the oil pan bolts. The pan is a Milodon, two of the black fiber type gaskets, windage tray, and the bolts are ARP stainless. I have to re-tighten the bolts every few weeks or I get leaks. Is there any way to correct this? Should I try loctite, thread sealant, or just get some regular steel bolts? Thanks I got tired of them doing this to went to studs and used the nuts that have the serrations to keep them locked in place ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Worked for me too.
Fastest 300
[Re: sasquatch]
#1818089
05/03/15 11:17 PM
05/03/15 11:17 PM
Posts: 1,385 Ohio
rck850
Ohio
All of the above but you also need to look at better crank case evacuation. Just a thought. This has been on my mind too. I tried hooking up a PCV last year and it made the car smell terrible, burn your eyes rich.
[Re: rck850]
#1818114
05/03/15 11:43 PM
05/03/15 11:43 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Is that the only nuts that are coming loose? Maybe you have a unbalanced engine that is causing a little to much vibrations.
[Re: rck850]
#1818130
05/04/15 12:02 AM
05/04/15 12:02 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
How about you try a better quality oil pan gasket? Your gasket is soft, therefore will not maintain enough load to keep the bolt torqued. I have Never had to re-torque my oil pan bolts and the gasket been on for 8 years, grade 5 hardware store bolts and plain old flat washers ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
