Driveline Speed Sensor Dana 60 #1815748
04/30/15 08:07 PM
04/30/15 08:07 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Have any you guys mounted a split collar on a Dana 60?
If not where do you put the driveline speed sensor?
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1815802
04/30/15 09:04 PM
04/30/15 09:04 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
I "hear" there is a yoke you can buy for the rear with a machined area. I mounted mine up at the trans on the slip yoke. The ring that came with my racepack was too large, but I had a strip of aluminum I cut and bent around the yoke and it was a perfect fit.
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1815854
04/30/15 10:16 PM
04/30/15 10:16 PM
MI
68shifter Offline
68shifter  Offline
MI
Strange just released a yoke to accept the collar. I thought MW had one too.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1815866
04/30/15 10:31 PM
04/30/15 10:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can buy the Strange or MW yokes or you can mount it on the slip yoke. We had ours on the slip yoke for years with 0 issues. Not a lot of movement there on a 4 link car.
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1815988
05/01/15 12:51 AM
05/01/15 12:51 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Trans yoke here as well.
Re: Driveline Speed Sensor Dana 60 [Re: FastmOp] #1816166
05/01/15 10:19 AM
05/01/15 10:19 AM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline
Ohio Joe  Offline
Takes a little machine work but it can be done . Strange yoke
66 Dart GT " Rat Racer"
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1816343
05/01/15 02:04 PM
05/01/15 02:04 PM
Carson City, Nevada
Carson City, Nevada
Thanks guys!
I can machine anything but I believe I'm going to put it on the slip yoke of the transmission. It will work out way better for me if I can install it there.
I'll post a photo or two when I finish installing it.
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1816348
05/01/15 02:06 PM
05/01/15 02:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
From my experience some yokes seem to have room to machine for the collar and some don't. But never had an issue on the slipyoke
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1816880
05/02/15 02:35 AM
05/02/15 02:35 AM
aZLiViN
aZLiViN
believe me.... it took me waaayyy to long to figure this out. laugh Aluminum strap was 1/16" thick X 3/4 wide you can buy at about any hardware store. cut it in 1/2 down the middle and bent it around the yoke. Fit like a champ!
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1816969
05/02/15 11:21 AM
05/02/15 11:21 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just bought one from strange for a dana with the collar, and 8 magnet ring. Very nice piece.
Re: Driveline Speed Sensor Dana 60 [Re: Biginchmopar] #1817019
05/02/15 12:58 PM
05/02/15 12:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You could also remove the maqgnets from the ring and epoxy them to the yoke itself. Done that once when there was no other option. Next time I will likely just buy a yoke now that they are more readily available. The 8 magnet rings are nice to smooth out the graph for sure.
Re: Driveline Speed Sensor Dana 60 [Re: Al_Alguire] #1817032
05/02/15 01:20 PM
05/02/15 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ended up making a ring for my 8 3/4... its a 4 magnet
set up.. they didnt make a ring for the 8 3/4
wave
Re: Driveline Speed Sensor Dana 60 [Re: dthemi] #1817349
05/02/15 10:24 PM
05/02/15 10:24 PM
Ohio Joe Offline
Ohio Joe  Offline
Just finished up the bracket for the sensor, maybe we will get car out sometime soon.
