PICTURE OF ORIGINAL BRAKE BOOSTER CHECK VALVE (E-BODY) #1816913
05/02/15 04:37 AM
05/02/15 04:37 AM
Sweden
71redcuda Offline OP
Sweden
Hello,
Can someone help out and post a picture of a original correct brake booster check valve, i have found one for my car, but the seller has 4 different styles of it..
THANKS
Nicklas
Re: PICTURE OF ORIGINAL BRAKE BOOSTER CHECK VALVE (E-BODY) [Re: 71redcuda] #1816922
05/02/15 08:29 AM
05/02/15 08:29 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For the AAR? If so, you want one like this;
Re: PICTURE OF ORIGINAL BRAKE BOOSTER CHECK VALVE (E-BODY) [Re: 71redcuda] #1817011
05/02/15 12:35 PM
05/02/15 12:35 PM
Sweden
Sweden
Thank you! I have seen the same style in green tint and the orange you show here..
Re: PICTURE OF ORIGINAL BRAKE BOOSTER CHECK VALVE (E-BODY) [Re: 71redcuda] #1817083
05/02/15 02:47 PM
05/02/15 02:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I had a white one at one point also, it looked identical on the outside, but I was told that it was for a late 1960s Hemi car.
If the diaphragms inside were different, it may explain the different colors, but I honestly do not know.
