Hoosier 10.5 x 30.5 What Pressure? (D06) #1816718
05/01/15 10:25 PM
05/01/15 10:25 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
We ran it the other week, and I am stumped on these new D06 slicks. I am thinking they like the higher air pressure of 12.0psi but it was inconsistent. 9psi seemed too low and unstable. What pressure should I be using?
Re: Hoosier 10.5 x 30.5 What Pressure? (D06) [Re: Dragula] #1816740
05/01/15 11:07 PM
05/01/15 11:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are they a radial slick ? Ron
Re: Hoosier 10.5 x 30.5 What Pressure? (D06) [Re: 383man] #1816792
05/02/15 12:02 AM
05/02/15 12:02 AM
Dragula Offline OP
Dragula  Offline OP
Slicks.....
Re: Hoosier 10.5 x 30.5 What Pressure? (D06) [Re: Dragula] #1816797
05/02/15 12:10 AM
05/02/15 12:10 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
12.5 to 15.0 psi
Re: Hoosier 10.5 x 30.5 What Pressure? (D06) [Re: Dragula] #1817077
05/02/15 02:39 PM
05/02/15 02:39 PM
Locomotion Offline
Locomotion  Offline
You have to tailor the air pressure to each application. Tire design, static weight, transfer, suspension, shocks, "hit", etc. all play a part. If you're not getting a full-width footprint at higher pressures and it's unstable at lower pressures, it may help to go to a wider rim.
I have Hoosier's 9" lightweight radial slicks on 10" rims and found that 20 - 21 lbs works best, despite a little extra wear in the center. But it's contacting all the way across the tread. When the rubber off the tread was fraying over the edge towards the sidewall too much, I added air. Some Stock class guys run down to 14! (I swap the slicks from side to side after every race to help even up the wear. I've never had equal side-to-side wear if I didn't.)
A wider rim will allow more air pressure, which stabilizes the sidewall and prolongs its life in addition to helping the car on the top end.
Re: Hoosier 10.5 x 30.5 What Pressure? (D06) [Re: Dragula] #1817082
05/02/15 02:46 PM
05/02/15 02:46 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The car in my sig wouldn't hook under 12 psi, best at 13-14
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Hoosier 10.5 x 30.5 What Pressure? (D06) [Re: Dragula] #1817374
05/02/15 11:09 PM
05/02/15 11:09 PM
Dragula Offline OP
Dragula  Offline OP
Well 13.0psi was not working 12.5 didn't work, 12.25psi and it hooked and I broke out. Seems to like 12.0-12.25 best. Been as low as 11.0 and it was unstable.
