does anyone rebuild 71 b body hood hinges? #1814602
04/29/15 03:11 PM
04/29/15 03:11 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Shop is putting the hood back on the 71 charger (car just painted) he told me the hinges were wore out. I see amd dont make them. Does anyone rebuild (mine)?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814611
04/29/15 03:21 PM
04/29/15 03:21 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
SMS Auto Restoration Services LLC
42 Manchester Road
Derry NH 03038
1-800-989-6660
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814613
04/29/15 03:23 PM
04/29/15 03:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814626
04/29/15 03:46 PM
04/29/15 03:46 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Depending on the quoted price for restoration... would think you could find decent used replacement hinges from an auto dismantler, eBay, swap meet, etc.
Granted, hood hinges do wear like everything else, but not as much as many other automotive parts.
I see a pair on eBay right now for $85, albeit that they should be stripped and repainted. Depending on condition, unless they are in as bad a shape as your current ones. Also, not sure but there may be good parts interchange with other Mopar vehicles (like trucks, Satellites, etc.)
http://www.ebay.com/itm/1971-74-B-Body-R...b09&vxp=mtr
Seems to me that the '71/'72 hinges are not the same as the '73 / '74 style.
Hood Hinges
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814627
04/29/15 03:47 PM
04/29/15 03:47 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Restorick did the ones on my '71 GTX and the turn around was fast and the quality was great.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814647
04/29/15 04:31 PM
04/29/15 04:31 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
70440+6bbl what did it run to have yours rebuilt?
The problem with buy a set of used ones. They may as bad if not worse then the ones I already have...
1971 charger
Re: does anyone rebuild 71 b body hood hinges? [Re: RSNOMO] #1814654
04/29/15 04:50 PM
04/29/15 04:50 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
42 Manchester Road
Derry NH 03038
1-800-989-6660
Only send your hinges to this guy if you want him to keep them and send back another pair and then lie about it. Bon Jour.
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814669
04/29/15 05:18 PM
04/29/15 05:18 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
send them to resto rick
i was happy with the ones he did for me.
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814672
04/29/15 05:21 PM
04/29/15 05:21 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Around $200 with return shipping.
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1814708
04/29/15 06:20 PM
04/29/15 06:20 PM
Ohio
jlatessa Online content
jlatessa  Online Content
Ohio
Try this first: put a hinge pin on an anvil and use a 2 pound sledge to swell the hinge shaft into a larger diameter. Be judicious in hitting the pin, lighter whacks at first, then increase the force until you start to see an improvement in reduced slop.
Used this on my 7os hinges and they now are like new.
Won't hurt to try....
Joe
Re: does anyone rebuild 71 b body hood hinges? [Re: jlatessa] #1814876
04/29/15 10:01 PM
04/29/15 10:01 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
RestoRick did mine, couldn't be happier. Fast and inexpensive.
I used to use SMS but the last set I had done had a problem on one and when I called them the guy treated me like dirt. I must of had 3 sets done by them over the years, no more.
RestoRick will do mine till the end of time!!!
Ron
Re: does anyone rebuild 71 b body hood hinges? [Re: formula_s] #1880305
07/28/15 08:45 PM
07/28/15 08:45 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
42 Manchester Road
Derry NH 03038
1-800-989-6660
You guys must be talking about another SMS. The one I spent almost a grand with has no other unhappy customers.
I had a long discussion this morning with Rod at a company named SMS about 4 pairs of hood hinges I sent to him. I'm not happy with the results at all and I let him know it. He claims that the rest of his customers are happy and I'm the only one to have a complaint about his work. By the way, all of my hinges were bead blasted in-house here, then engraved with markings on the back side before shipping out. All of the markings have since vanished. I don't think I paid extra to have my identifying markings removed.
Re: does anyone rebuild 71 b body hood hinges? [Re: jlatessa] #1984828
01/06/16 01:00 PM
01/06/16 01:00 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Joe
You can do this, however it doesn't address the mesh of the teeth. Every set of hinges I've rebuilt needs welding & fitting of the teeth, even ones that have minimal slop in the pins. The teeth were production stamped with poor fit from day one.
As for hammering the rivet/pins, it will work to a certain degree, however, because you're dealing with a somewhat egg shaped wear the slop will return quicker than properly reamed holes with new pins.
Re: does anyone rebuild 71 b body hood hinges? [Re: toplescuda] #1984835
01/06/16 01:11 PM
01/06/16 01:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
SMS did a e-brake assy for me years ago. All I`m going to say is not again.
