Please help me ID a torque convertor
#1814180
04/28/15 09:46 PM
04/28/15 09:46 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Hey guys, I was sorting some parts today and I came across this convertor. No name, but it has a set of what look like part #'s. I have not been able to locate anything on those #'s but thought maybe someone here has seen or had one of these. I measured it across and the stock 71 727 six pack convertor next to it was over 11 inches diameter and this one came in right around 10 inches. The stock one looks MASSIVE compared to this one in diameter and thickness. I did find something on the web that it might be a TCI but I can not get any cross reference on that for specs. Anyone know what this one is??
Numbers on it K1422K U7185
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: Please help me ID a torque convertor
[Re: vette1986]
#1814455
04/29/15 10:04 AM
04/29/15 10:04 AM
vette1986
Wahoo Nebr
Is this a 383 convertor? I guess that is what I am trying to find out is if anyone knows what it is and what its specs might be?
[Re: vette1986]
#1815009
04/30/15 12:15 AM
04/30/15 12:15 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Looks like you have a good TC...spec says stall about 1500 rpm higher than stock. You need to get the flex plate and bolts that goes with it because it takes bigger Hemi size bolts.
[Re: RoadRunnerJD]
#1815636
04/30/15 06:11 PM
04/30/15 06:11 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
TCI calls the #1422 Street Fighter a 10" converter but, from the look of the ring gear, it's no smaller than a factory 11". Advertised as 3600-3800 stall.
[Re: vette1986]
#1815845
04/30/15 10:05 PM
04/30/15 10:05 PM
vette1986
Wahoo Nebr
Thanks for all the input guys as I have now discovered it is too loose for my combo. I need something like the turbo action 17501. I guess I will have to shelf this one. thanks
