68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header #1813521
04/27/15 11:40 PM
04/27/15 11:40 PM
Chicago, IL
1970Moparmann Offline OP
Chicago, IL
Hey guys, is anyone running a 383/400 with a TKO600 with TTI headers? Need proof that they will fit the bell housing and hydraulic clutch. Called a few places and no one is confident with an answer.
TTI said to go with 400SR-218 (SR Step Headers), but didn't know 100% if it would fit.
I have 440Source Stealth heads also.
Currently have 1 7/8 Schumakers, but can't get a mini starter in it, plus the 1 7/8 is small for the engine build.
This is for a 68 Charger with original K Frame.
Thanks.
Re: 68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header [Re: 1970Moparmann] #1813813
04/28/15 12:21 PM
04/28/15 12:21 PM
Chicago, IL
Chicago, IL
Anyone?
Re: 68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header [Re: 1970Moparmann] #1813823
04/28/15 12:41 PM
04/28/15 12:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
1 7/8 headers too small? What are you building a 500 inch stroker? I don't know if they'll fit but I like my Hooker 2" super comps. You might be able to use them if you modify the collector area.
Coming soon!!!!
Re: 68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header [Re: 1970Moparmann] #1813902
04/28/15 02:45 PM
04/28/15 02:45 PM
Chicago, IL
Chicago, IL
Correct - 500 Stroker. It's pushing about 550 or so.
Re: 68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header [Re: 1970Moparmann] #1814354
04/29/15 01:03 AM
04/29/15 01:03 AM
IN
ahy Offline
ahy  Offline
IN
I'm running 1 7/8" TTI's with TKO 600 and hydraulic clutch (TO bearing type) on a 400 core engine. Fits fine/as advertised on a '70 E. I don't think the hydraulic clutch adds to clearance problems... though the low deck with certain heads did not seem to be recommended or fit with 2" headers at the time I purchased mine thus the 1 7/8".
Re: 68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header [Re: 1970Moparmann] #1814604
04/29/15 03:12 PM
04/29/15 03:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW I only picked up about 1.5mph in the 1/4 from jumping from the 1 3/4" to 2". If you can find a 1 7/8" header I doubt you'll be leaving much on the table.
Coming soon!!!!
Re: 68 Charger 400 Block, TKO 600 with Hydraulic Clutch - header [Re: 1970Moparmann] #1815133
04/30/15 02:35 AM
04/30/15 02:35 AM
Chicago, IL
Chicago, IL
Thanks guys. I talked to someone else at TTI today and received better information. FYI, they are 3 weeks delayed on orders currently.
