Solid 7290 u-joint, where can I find one?UPDATE #1813332
04/27/15 08:29 PM
04/27/15 08:29 PM
Ohio
moparjoe360.4 Offline OP
Ohio
I'm in need of a solid 7290 u-joint and the only one I can seem to find is a Lakewood from Summit. The local napa can get non greaseable ones but the counter guy said they're still cross drilled. I highly doubt Lakewood is the only one who manufactures solids nowadays but I could be wrong. Any ideas?
Re: Solid 7290 u-joint, where can I find one? [Re: moparjoe360.4] #1813355
04/27/15 08:57 PM
04/27/15 08:57 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Rock auto. Mancini, Dr. Diff
Re: Solid 7290 u-joint, where can I find one? [Re: moparjoe360.4] #1813780
04/28/15 11:33 AM
04/28/15 11:33 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Google Dana Spicer 5-811X thumbs
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Solid 7290 u-joint, where can I find one? [Re: MoParFish] #1813867
04/28/15 01:55 PM
04/28/15 01:55 PM
Locomotion Offline
Locomotion  Offline
In my opinion, Spicer makes the best solid joints. I've been using their 7260 joints with no problems.
Re: Solid 7290 u-joint, where can I find one? [Re: moparjoe360.4] #1813941
04/28/15 03:40 PM
04/28/15 03:40 PM
Guitar Jones Offline
I used the Spicer joints in my Scamp. The old 12 valve got Neapco joints. I don't really know much about them though.
Re: Solid 7290 u-joint, where can I find one? [Re: moparjoe360.4] #1813957
04/28/15 03:54 PM
04/28/15 03:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Look for the Neapco brand and inspect them before buying them to make sure they are not drilled scope up
Re: Solid 7290 u-joint, where can I find one? [Re: moparjoe360.4] #1814905
04/29/15 10:35 PM
04/29/15 10:35 PM
Ohio
Ohio
Thanks for all the replies. I like the Dana/Spicer as well and I've seen their non greaseable listed but wasn't sure if they were cross drilled or not. They're definatly my preference so I'll do a bit more searching. I've got to get a move on so I'm ready for the Chrysler Power race in Columbus in 2 weeks. up
Re: Solid 7290 u-joint, where can I find one? UPDATE [Re: moparjoe360.4] #1823929
05/11/15 01:38 AM
05/11/15 01:38 AM
Ohio
Ohio
Ok so I've had the Spicer 5-811x in and out multiple times because it was a clip wdith off I I was tinkering with it tonight and thought I'd try a used spare solid I had laying here just incase it was an issure with the new Spicer. I had the same results with it. I then looked the bad u-joint over again an found the clip slot slightly closer to the X body of the u-joint. So it seems the shop that built my driveshaft used [censored] caps on the driveshaft side of the u-joint and told me they were 7290's. The rest of the u- joint carries the same cap #s and X body #s are on the good used u-joint's caps and X body and both came from the same shop. From what I can tell both old u- joints look to be Neapco brand. Any ideas where to find a solid [censored] joint or different caps for my 5-811x?? I'm down to the wire now I'm leaving Friday morning for Columbus! Did I mention I drive it the 160 mi to the track race it n drive it home? help panic
Re: Solid 7290 u-joint, where can I find one? UPDATE [Re: moparjoe360.4] #1823957
05/11/15 02:51 AM
05/11/15 02:51 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Here is a possibility. The 7290 Detroit and 3r Saginaw(GM) series are very close dimensionally. Both have 1.125 caps but 7290 is 2.622 between the ears and 3R GM is 2.556. I have seen some shops use 3R weld yokes, due to availability, and a conversion U-joint to get back to 7290. If you measure between the ears and get 2.556, you will need a 3-3133 Neapco to get you going. The 3-3133 is a 3R/7290 conversion joint.
Or, a 5-795X is the solid body 3R. You may be able to swap two caps from the 5-795x onto the 5-811x and vise versa but MUST make sure bodies are identical. The 3-3133 is a greasable joint but wouldn't be too worried as we were beating on those things long before the solid bodies became "all the rage" with the cool kids thumbs
Re: Solid 7290 u-joint, where can I find one? UPDATE [Re: moparjoe360.4] #1824198
05/11/15 02:59 PM
05/11/15 02:59 PM
Ohio
Ohio
Your theory seems very probably to me because when I picked up this driveshaft it had greaseable joints I complained and they put solid body's in for me. I betting the just put the 3r to 7290 caps on a 7290 solid body.
Re: Solid 7290 u-joint, where can I find one?UPDATE [Re: moparjoe360.4] #1826375
05/14/15 01:21 AM
05/14/15 01:21 AM
Ohio
Ohio
Well I finally got it back in one big hunk tonight. I've got to send out a big thank you to MoparFish for pointing me in the right direction. The 5-795x GM and 5-811x Chrysler use the same body so I now have a spare as well. Thanks to every one who have given me the info I was searching for and couldn't seem to find. Now if Mother Nature cooperates it should be an awesome weekend!! drive
Re: Solid 7290 u-joint, where can I find one?UPDATE [Re: moparjoe360.4] #1826395
05/14/15 01:51 AM
05/14/15 01:51 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Glad it worked out thumbs
