Big Block Lightweight SFI Bellhousings? On a Budget???
#1811861
04/25/15 09:21 PM
04/25/15 09:21 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
So I just dropped 51 pounds. (Yay,Me!) After I have Liberty go through the gears, I'm going to get a Passon aluminum case setup for my four speed. Already have a 20 pound aluminum 143 tooth flywheel. Does anyone know of an aluminum or lightweight steel housing that is affordable? Quicktime doesn't make one for a 143 tooth flywheel. Trick Titanium and others are $2,000 and up. I just need something for a bracket car, not a Prostock or Promod.
[image][/image]
Re: Big Block Lightweight SFI Bellhousings? On a Budget???
[Re: roadhazard]
#1811972
04/25/15 11:31 PM
04/25/15 11:31 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
$2000. for a bell housing?????? I could think of a lot of things to over come the weight of a steel bell.
[Re: roadhazard]
#1811984
04/25/15 11:45 PM
04/25/15 11:45 PM
sgcuda
If you get the Trick can, you'll have bragging rights Is 2K a used price? New. But doesn't include a liner. What do I need a liner for, anyway? Can I run it without a liner? Planning on using a sintered iron single disc setup. Racingjunk has Browell cans for $800, but I don't see any holes for linkage, and they only bolt up to Lenco's. Damn, why is racing a Mopar always such a pain in the butt?
[image][/image]
[Re: sgcuda]
#1812100
04/26/15 01:51 AM
04/26/15 01:51 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I went through this trying to get something to work with my Lenco deal. The problem with most of the higher end used bells for sale is depth. The stock Mopar dimension is 7.5" and most of the cans you see are 8" or better. That won't work so hot with a single or even dual disc clutch in most cases. If you figure that out then you have to open up the fire wall, etc. I plan on getting a new Browell from MR2 Performance or possible a custom from Lakewood/Quicktime. They were both around $1000 from what I remember. Let us know what you figure out.
[Re: sgcuda]
#1812219
04/26/15 11:47 AM
04/26/15 11:47 AM
sgcuda
Double checked the Trick website. $1,995 is there price for an SFI aluminum can. Not a bad price, in comparison, I guess. If I can order a Quicktime custom piece to fit my combo for a grand, that would be great! Something to check into... I have religiously run Ram clutches, usually using a 10.95" B&B 3200 lb. plate and Ram Metallic sprung disc. Peer pressure has me leaning towards a Long style plate and sintered iron disc, which they only make in an 11" setup. I have never had an issue with the B&B setup, but I was only running 9.90's with the steel head motor. Lot's more power with the 500" Indy head combo. Trying to keep the hemi box alive a little longer. McLeod still only lists Chevy housings. If I go for a Trick piece, I'd probably check into getting it drilled for a Liberty or G Force pattern, also. Wanting to go clutchless down the road.
[image][/image]
[Re: sgcuda]
#1812477
04/26/15 07:15 PM
04/26/15 07:15 PM
sgcuda
Browell's website shows all of their 6.1 housings are $2,075. I don't know who M2R is. Member? Seller? I plan on one of the new Ram Long PP and a sintered iron disc. Looks like a good setup to allow slip on the launch and gear changes. I'll probably buy whatever Passon has available and order main case later on. Makes my cash out a little easier, anyway. Car weighed somewhere near the 2,800 mark before. Trying to get her down between 2,600 and 2,700 ready to race. I'm guessing bellhousing, flywheel, trans case and me should do it. Plus, I'm changing over to Strange struts with and brakes at minimum, if I don't change out the front end all together.
[image][/image]
[Re: sgcuda]
#1813066
04/27/15 02:45 PM
04/27/15 02:45 PM
sgcuda
Called tech support at prestolite performance on a custom Quicktime bell. Jimmy said one could probably be built around $1,200-$1,500. Takes about 90 days. Didn't seem very enthusiastic about it, but said it shouldn't be a problem. Anyone have any experience with Quicktime? I thought I heard something about the quality of their bell's.
[image][/image]
[Re: sgcuda]
#1813117
04/27/15 03:42 PM
04/27/15 03:42 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
So I just dropped 51 pounds. (Yay,Me!) After I have Liberty go through the gears, I'm going to get a Passon aluminum case setup for my four speed. Already have a 20 pound aluminum 143 tooth flywheel. Does anyone know of an aluminum or lightweight steel housing that is affordable? Quicktime doesn't make one for a 143 tooth flywheel. Trick Titanium and others are $2,000 and up. I just need something for a bracket car, not a Prostock or Promod. If it's a BRACKET car does it really need a lightweight bellhousing ? Heads up maybe , but brackets ??? Also you'll need an SFI bell and I imagine that an Alum. bell with a liner that can withstand a clutch explosion is going to weigh as much as a steel SFI bell ???
[Re: sgcuda]
#1813196
04/27/15 05:37 PM
04/27/15 05:37 PM
sgcuda
Already have a Lakewood shield. Those things are heavy. The object here is to lose some weight during the rebuild.
[image][/image]
[Re: roadhazard]
#1813510
04/27/15 11:28 PM
04/27/15 11:28 PM
Posts: 608 TN
1DGEMAN
TN
The clutch flywheel combo you have is 40 year old technology. Step up to 130 tooth wheel and a long pp. Then you can go on e bay and buy a Quicktime bellhousing for under $600. My entire clutch assembly weighs only 2 lbs more than your flywheel. But what I have is overkill for a bracket car. Call up Rob Youngblood at Advanced Clutches he can set you up with what you need and it will live and not break parts.
Real Men shift for themselves
[Re: 1DGEMAN]
#1813557
04/28/15 12:27 AM
04/28/15 12:27 AM
sgcuda
The clutch flywheel combo you have is 40 year old technology. Step up to 130 tooth wheel and a long pp. Then you can go on e bay and buy a Quicktime bellhousing for under $600. My entire clutch assembly weighs only 2 lbs more than your flywheel. But what I have is overkill for a bracket car. Call up Rob Youngblood at Advanced Clutches he can set you up with what you need and it will live and not break parts. What kind of price range am I looking at? His stuff looks all high end.
[image][/image]
[Re: sgcuda]
#1813571
04/28/15 12:38 AM
04/28/15 12:38 AM
Posts: 608 TN
1DGEMAN
TN
You are talking about spending 2grand on a bellhousing and still running an outdated clutch. Buy the quicktime at $600 that frees up $1400. I don't quote Rob's prices call him up talk to him. He is a great guy to deal with and has extensive clutch knowledge. Tell him Rod sent you.
[Re: sgcuda]
#1813582
04/28/15 12:45 AM
04/28/15 12:45 AM
sgcuda
OK, all ready. Sheesh. I get this pressure from my wife. I'll call him tomorrow. Thanks. BTW, with his flywheels, have you noticed a drop in 60ft. times? What trans are you running?
[image][/image]
[Re: sgcuda]
#1827539
05/15/15 10:30 PM
05/15/15 10:30 PM
sgcuda
Scored a Quicktime bell on E bag for $575 shipped. Next stop, aluminum trans housing, and then an Advanced clutch setup. Guess I'll clean up my Lakewood shield and list it with my 143t aluminum wheel.
[image][/image]
