1988 Ramcharger 4x4 steering column #181177
01/02/09 12:44 AM
01/02/09 12:44 AM
Anonymous OP
Anonymous OP
Hi all, I have a 1988 Ramcharger with a wobbly steering column. I tore it down and tightened the 4 bolts from hell and this did little if anything to tighten it up. I was wondering if anyone here knows if i can just put a non tilt column in and eliminate the whole tilt problem? whats the difference between the 2x4 and the 4x4 column? I also have a 92 ramcharger 2x4. Will that column work? any help will be very welcomed since it's not really safe at this point to drive the truck. The shifting is way messed up do to the column being loose.
Re: 1988 Ramcharger 4x4 steering column #181178
01/02/09 02:26 AM
01/02/09 02:26 AM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
if its a tilt column, you get the bushing rebuild kit for 82-87 chevy truck tilt column. major PITA job, but it fixes it right up.
Re: 1988 Ramcharger 4x4 steering column #181179
01/02/09 05:06 PM
01/02/09 05:06 PM
Windsor, Ontario, Canada
Canadart Offline
Canadart  Offline
I had an 89 with the same problem.... in the 10 months i was driving it i had to mess around with that column 4 times the last time i put blue loc tite on those 4 bolts that kept coming loose. It helped me... hope it helps you.
I found my info on ramchargercentral.com
1970 Dart Swinger 440
