Does anybody here work with lead.. #181167
01/02/09 12:43 AM
01/02/09 12:43 AM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
Or whatever the substance is anymore. Not sure if "leading" is EPA approved but whats its' replacement? Is anyone doing it? I have thought that IF I build an old style street rod{ever}, I'd like to smooth the seams. Is it easier to just use mig,tig or the body panel glue. I like learning to do new things. I need to learn to Tig aluminum but I'd like to learn the lost arts too..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Does anybody here work with lead.. [Re: KatFysh] #181168
01/02/09 01:20 AM
01/02/09 01:20 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Don't know what the "EPA" position is, but I know you can buy the stuff from various vendors. Got my first bit from Eastwood...looking for a more local supplier now. I haven't done alot of it, but it's been fun so far!
2 Demons...no, not my kids!
Re: Does anybody here work with lead.. [Re: 4speeds4me] #181169
01/02/09 02:57 PM
01/02/09 02:57 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have the eastwood kit and have used it a couple times. It's relatively easy to understand how to do it, but it takes some decent hand + eye coordination to be good at it especially on vertical surfaces. There is a fine line between the lead being warm enough to make it stick and so warm that it wants to run off the car.
Re: Does anybody here work with lead.. [Re: Neil] #181170
01/04/09 02:43 AM
01/04/09 02:43 AM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
I have seen the Eastwood kit. I figured that if and when the time came, I'd use that kit.. Nobody else has tried it..
Re: Does anybody here work with lead.. [Re: KatFysh] #181171
01/04/09 02:57 AM
01/04/09 02:57 AM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
Yes, I do and have for 25 years. But the lead I work with comes out of the end of my Sig Sauer! One squeeze at a time!
Re: Does anybody here work with lead.. [Re: RUMBLON] #181172
01/04/09 02:45 PM
01/04/09 02:45 PM
4speeds4me Offline
4speeds4me  Offline
Too funny, Dave!
Re: Does anybody here work with lead.. [Re: 4speeds4me] #181173
01/04/09 03:34 PM
01/04/09 03:34 PM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
Re: Does anybody here work with lead.. [Re: RUMBLON] #181174
01/05/09 01:13 AM
01/05/09 01:13 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Doesn't it tend to make holes instead of filling them?
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: Does anybody here work with lead.. [Re: shinnery] #181175
01/05/09 01:43 AM
01/05/09 01:43 AM
4speeds4me Offline
4speeds4me  Offline
In my experience there's way less chance of pinholes and stuff with lead than there will ever be with plastic fillers...and less chance of moisture getting underneath and causing cracking, rust, etc.
Re: Does anybody here work with lead.. [Re: KatFysh] #181176
01/05/09 11:07 PM
01/05/09 11:07 PM
Buzzardbreath Wyoming
BigBird Offline
BigBird  Offline
Even if you lead a body seam you need to weld it or it will crack just as any filler would. Working lead takes practice like any skill. Done properly it will last a lifetime. Done poorly it is no better than plastic fillers.
