Tom's Bulldozer is getting some updates #1737940
01/24/15 09:39 PM
01/24/15 09:39 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Through the past 8 months, Tom and I have realized that the YJ based SOA front suspension on his '58 Willys Wagon is not up to the task. We have decided on a few ways to improve the durability of the front suspension and increase the vehicles offroad performance.
The old 63" wide axles are being swapped out for some full width axles and the front suspension is being converted to a 3-link with coilovers. The axles gears are being exchanged to 4.88's from the 4.10's in preparation for future 42" Pitbull Rockers.
Since Tom drives like his rig like a bulldozer and hitting trees has bent both his front leaf springs, a beefy 3-link will take care of that issue. Most link suspension use 2"OD 1/4" wall tubing for the links and 1.75"OD 1/8" wall tubing for the track bar. Tom's will use 2.25"OD 3/8" wall tubing for the links and 2"OD 1/4" wall tubing for the track bar. He is not bending these
The only differences out back are the gear change, axle width, and the TMR shave kit to smooth out the bottom of the axle.
I have accumulated all of the parts and have begun preparing the axles for the swap. Tom is handling the gear/locker installs and brakes, while I handle the welding and suspension end.
I just welding on the first part of the front axle today, an Artec truss.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1737941
01/24/15 11:10 PM
01/24/15 11:10 PM
places
79powerwagon Offline
places
Jeepers!
(No pun intended)
How the heck do you keep the tubes straight when welding THAT much steel onto them???
This whole project is darn cool!
Re: Tom's Tastykake is getting some updates [Re: 79powerwagon] #1737942
01/25/15 01:36 AM
01/25/15 01:36 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
That truss looks like a piece of the George Washington Bridge!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Tom's Tastykake is getting some updates [Re: DusterDave] #1737943
01/25/15 11:04 AM
01/25/15 11:04 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Re: Tom's Tastykake is getting some updates [Re: 79powerwagon] #1737944
01/25/15 11:05 AM
01/25/15 11:05 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Jeepers!
(No pun intended)
The tubes are .500" wall, they don't warp
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1737945
01/25/15 01:35 PM
01/25/15 01:35 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Jeepers!
(No pun intended)
Gotta love front Dana 60's, especially kingpin versions like yours!
Is it safe to assume you're going to add high steering to it?
Re: Tom's Tastykake is getting some updates [Re: DusterDave] #1737946
01/25/15 03:29 PM
01/25/15 03:29 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Only high steer for the drag link. There will be tie rods in the stock location in order to keep them out of the way of the panhard bar.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1737947
01/25/15 05:32 PM
01/25/15 05:32 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I'll be watching this conversion closely. I recently acquired a KP D60, and was thinking about doing away with the leafs up front and installing it with a 3 link & coil-overs.
Re: Tom's Tastykake is getting some updates [Re: DusterDave] #1811679
04/25/15 05:04 PM
04/25/15 05:04 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
The 3-link has been done. Here are the step by step pictures, aside from the painting portion.
I made Tom remove his old axle, which is actually the front axle to my M37. You can see how bad the front springs were beaten up.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811683
04/25/15 05:06 PM
04/25/15 05:06 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Here is the empty spot and the new axle getting ready to go into position
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811686
04/25/15 05:08 PM
04/25/15 05:08 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Upper frame link tack welding in place and heims in place. Axle positioned.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811689
04/25/15 05:09 PM
04/25/15 05:09 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Nice front shot of the Artec Dodge D60 truss. Mock up arms made with roll cage tubing.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811693
04/25/15 05:11 PM
04/25/15 05:11 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Actual arms made with 2.25" 3/8" wall DOM. Fat and stumpy.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811699
04/25/15 05:13 PM
04/25/15 05:13 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Frame panhard bar bracket tack welded in place. And the Artec Dodge truss mounted panhard bar bracket tack welded to the truss.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811705
04/25/15 05:14 PM
04/25/15 05:14 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
panhard bar is made. Now I could check the flex and look for binding.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811706
04/25/15 05:15 PM
04/25/15 05:15 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
everything is welded and painted and in for final assembly.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811708
04/25/15 05:16 PM
04/25/15 05:16 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Back on all four wheels and brakes bled
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1811709
04/25/15 05:16 PM
04/25/15 05:16 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
The rear axle swap will be next week.
Re: Tom's Tastykake is getting some updates [Re: Defbob] #1812007
04/26/15 12:02 AM
04/26/15 12:02 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Very nice work
