180 psi what octane do i need?
#181086
01/01/09 10:26 PM
01/01/09 10:26 PM
I have 180psi cylinder pressure on my rebuilt engine. I am having some problems with pinging and detonation and I have the timing retarded. I am running 8 gallons of 91 octane with a bottle of Lucas octane booster that treats 25 gallons. I have perfect quench, aluminum heads, polished cambers and pistons, with the hot spots taken down and I am running as cold of plugs as I can get.
Re: 180 psi what octane do i need?
#181087
01/01/09 10:35 PM
01/01/09 10:35 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Octane booster in a bottle really doesn't do much. What does your advance curve look like? Where is your timing now? Are you jetted lean?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#181088
01/01/09 10:40 PM
01/01/09 10:40 PM
Posts: 2,275 Kissimmee, Florida
aarlucas
Kissimmee, Florida
I have 185 psi and I don't have any problems with 91 pump gas. I have aluminum heads too. I run 36* of timing.
Are you running lean?
[Re: aarlucas]
#181089
01/01/09 10:57 PM
01/01/09 10:57 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
to hot or to lean. did you check yur timming tab to make sure ts right with the balancer?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#181090
01/01/09 11:47 PM
01/01/09 11:47 PM
well i know lean can cause that. i just wanted to know if my compression was with in the abilities of 91 octane. the octane boosters sure helped but they cannot get rid of the ping. i have some larger injectors i am going to put in it.
#181091
01/02/09 12:48 AM
01/02/09 12:48 AM
just my opinion, but i think your on the edge at best of having enough octane for that cylinder pressure. to make it work you need to have everything just about perfect.
#181092
01/02/09 12:51 AM
01/02/09 12:51 AM
sixpackgut
Charleston
i didnt notice you said 91. that will rattle my motor. 93 is fine though
[Re: 70cudaproject]
#181095
01/13/09 02:31 PM
01/13/09 02:31 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I'm running a SB with J's and 205 cyl psi on 93, but i have a fresh air intake, heat crossover blocked, Carb spacer, 32 total, very cold plug, high stall, ect.. ect.. 180 should be fine with 91 if everything is correct.
[Re: MoparforLife]
#181098
01/13/09 05:58 PM
01/13/09 05:58 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
The engine that I built for my brothers car has 185 average PSI and he has to run 95 octane. His car weighs only 3250 with him in it and has 4.30 gears. I think the heavier the car with the lower numerical rear gear ratio is going to have a worse pinging problem that if the same engine was in a lighter car with higher numerical number gears in the rear like 4.30s. Many factors outside of quench, cylinder pressure and coolant temperature need to be taken into consideration when asking about the right octane for a given combination. I personally think that 180 PSI for the most part is too high for 91 octane. Can it be done?...Yes with the right combo....but not for most.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#181099
01/13/09 06:49 PM
01/13/09 06:49 PM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
What EFI system?? Is the distributor advanced locked?? Is the distributor phased properly??
Can you tune the advance on the system you're running?
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
