69 440 P/S cooler question. #1810687
04/24/15 01:27 AM
04/24/15 01:27 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Just got my P/S cooler for my 69 440. I have a Saginaw pump. When I tried to install the cooler I could not bolt it on because the return line on back of the pump hits the cooler bracket. I tried to Google an image for reference but could not find an image for the rear of the pump with cooler attached. I thought about bending the pump return line straight to the side instead of the current upward angle but I did not want to do this without researching first. Does anyone have a rear image for this setup or have any advice?
ps cooler 1.jpg (377 downloads)
ps cooler 2.jpg (345 downloads)
Re: 69 440 P/S cooler question. [Re: GKMOPAR] #1810812
04/24/15 11:28 AM
04/24/15 11:28 AM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
looks like line from power steering pump is off...not the best images but you get the picture. http://a12mopar.com/yabb/YaBB.pl?num=1206059923/3#3
Re: 69 440 P/S cooler question. [Re: GKMOPAR] #1810841
04/24/15 12:10 PM
04/24/15 12:10 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
I believe the pump bucket is different with the cooler from what I remember.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 69 440 P/S cooler question. [Re: GKMOPAR] #1810994
04/24/15 03:42 PM
04/24/15 03:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The line on my pump is almost parallel,not angled up like you show.
Re: 69 440 P/S cooler question. [Re: GKMOPAR] #1810995
04/24/15 03:42 PM
04/24/15 03:42 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is from a 69 R/T I just sold. Maybe this will help.
Re: 69 440 P/S cooler question. [Re: LYNCHROAD69.5] #1811095
04/24/15 07:15 PM
04/24/15 07:15 PM
Massachusetts
Massachusetts
Try the link I posted again...a member just posted some additional pictures that should answer your question.
Re: 69 440 P/S cooler question. [Re: GKMOPAR] #1811294
04/25/15 12:23 AM
04/25/15 12:23 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Thanks for the pictures. I think I can make it out. Looks like the return line on the back of the pump comes straight out to the side. That's what I thought but wanted to verify. Thanks again for the help!
