AN block plug #1809894
04/23/15 01:10 AM
04/23/15 01:10 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
I have a World alum. block. I need one of the plugs that screw into the side of the block.anyone know where to get one?its not actually an AN fitting,its a nps frost plug.i can get 4 from Bill Mitchell but I only need one.
Re: AN block plug [Re: bonefish] #1810099
04/23/15 01:03 PM
04/23/15 01:03 PM
dogdays Offline
dogdays  Offline
NPS = straight threads with the same TPI for the size as the NPT tapered threads.
McMaster-Carr?
R.
Re: AN block plug [Re: bonefish] #1810131
04/23/15 01:40 PM
04/23/15 01:40 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Maybe try KB. They may have some on hand. If not they could tell you where to look.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: AN block plug [Re: 1320Dart] #1810226
04/23/15 04:05 PM
04/23/15 04:05 PM
dogdays Offline
dogdays  Offline
Seems simple to me to get them from Bill Mitchell. I've just spent the last 6 minutes looking (for me that's a lifetime of looking online) and while they are out there, they're really not easy to find. Also they look like plumbing parts, not racecar parts.
How does the plug seal? NPS threads need some sort of seal. One type I found has a hex head with an o-ring under it. Also not cheap at several dollars each.
R.
Re: AN block plug [Re: 1320Dart] #1810245
04/23/15 04:27 PM
04/23/15 04:27 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
they seal with a o-ring.i only need one .I havnt heard back from Mitchell.the bummer is,i have one I just cant find it and I know as soon as I order one mine will appear in plain sight right before my nose.if I don't hear back from Mitchell I,ll give KB a call.
Re: AN block plug [Re: dogdays] #1810248
04/23/15 04:33 PM
04/23/15 04:33 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
R.
I found some online but they didn't have the size I need.the Mitchell web site says they are 1.000 x 11.5 nps.
Re: AN block plug [Re: bonefish] #1810827
04/24/15 11:58 AM
04/24/15 11:58 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
I FOUND IT!!!!. thanks for the input punkrocka boogie beer realcrazy
Re: AN block plug [Re: bonefish] #1810830
04/24/15 12:02 PM
04/24/15 12:02 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I thought that fitting was a -12 ORB (O-ring boss). If it is, that is fairly common. Jeg's, Summit etc.
2011 Drag Pak Challenger
Re: AN block plug [Re: rickseeman] #1810885
04/24/15 01:07 PM
04/24/15 01:07 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
-12 way to small.
