what times should i run with this combo #1809466
04/22/15 03:06 PM
04/22/15 03:06 PM
blytheville, arkansas
jpalmore Offline OP
jpalmore  Offline OP
I have a 69 coronet with fiberglass hood,5.13 gears,hossier 29x14.50 quicktimes,dynamic 4200 stall,pro built trans with low first gear,496 with edelbrock rpm unported with comp 928 springs,11.0 compression,comp hydraulic flat with .601 lift on both sides.The car weighs 3400 to 3500 with me in it and a 950 cfm holly quickfuel and this is 1/8th mile only
Re: what times should i run with this combo [Re: jpalmore] #1809484
04/22/15 03:30 PM
04/22/15 03:30 PM
God's Country Maryland
GODSCOUNTRY340 Offline
7.40-7.50
Re: what times should i run with this combo [Re: jpalmore] #1809507
04/22/15 03:50 PM
04/22/15 03:50 PM
jpalmore Offline OP
jpalmore  Offline OP
Trying to get it to 7.00 any ideas
Re: what times should i run with this combo [Re: jpalmore] #1809514
04/22/15 04:00 PM
04/22/15 04:00 PM
Oh
P
parksr5 Online content
parksr5  Online Content
P
Oh
I think you will be quicker than 7.40-7.50's. I would guess more around the 7.10 area; maybe faster if the tune is razor sharp. I'm close to 3700 lbs and have a much milder iron headed 470 and I run 7.70's on a set of 28 x 10.50 Mickey Thompson Sportsman Pro's. I think there is more in my car too.
Re: what times should i run with this combo [Re: jpalmore] #1809535
04/22/15 04:16 PM
04/22/15 04:16 PM
jpalmore Offline OP
jpalmore  Offline OP
Thanks that sounds like more like I guessed
Re: what times should i run with this combo [Re: jpalmore] #1809597
04/22/15 05:35 PM
04/22/15 05:35 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Probably have better luck asking this in the race forum as well...
