Re: '74 Chilli Challenger Project *DELETED*
[Re: 69Cuda340S]
#180885
01/10/09 10:09 AM
01/10/09 10:09 AM
Post deleted by theiceman
#180886
01/19/09 11:58 PM
01/19/09 11:58 PM
Posts: 112 SK, Canada
etek
SK, Canada
I can't recall if I included in this thread all the problems I had with the PUI upholstery I ordered through YearOne, but what happened was as I was installing the fronts I noticed the covers where missing crucial parts called pulls, that allow you to hook the inner portions into the foam bucks so they are pulled taught. I had to send photo's of the originals and call PUI to get them to add the pulls seperately so they would match the OEM parts. Obviously they have been selling these covers without the right parts attached!! For my troubles PUI send me a new set, properly sewn, and YearOne gave me a big fat credit. :-\ Par for the course, I was installing the rear covers last weekend only to find that they were also sewn with errors. :stomp: This time they weren't missing pull (there aren't any on the rears) but they were obviously "rushed" or "pushed" though the machine and missed Quality Control altogther. As you can see from the photos, the bottoms are puckered and the seat back corner stitches don't even meet the corners. Unbeleivable. So after ANOTHER wasted install, I have contacted YEar One again to get them repalced. By the time I actually get a good set and get them installed, I'll have enough credit to build another car! ![](/ubbthreads/images/graemlins/tongue.gif) ullinghair: ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/100_0969-1.jpg) ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/img_1435.jpg) ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/100_0967-1.jpg) ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/100_0966-1.jpg) On the bright side, I resprayed the door and quarter panels with a different White, which is a MUCH closer match to the original white. It has a lot more yellow in it than the initial white I used. ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/img_1438.jpg) ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/img_1440.jpg) As well, I used WD-40 to remove all the glue from the woodgrain decal on the console plate. Came out clean as a ...... ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/100_0937.jpg) ![](http://i305.photobucket.com/albums/nn201/e-tekpics/Chally%20Interior%20Jan08/100_0946.jpg)
[Re: etek]
#180888
01/26/09 10:18 PM
01/26/09 10:18 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
Looking fantastic man...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
[Re: burdar]
#180898
07/25/09 12:14 AM
07/25/09 12:14 AM
etek
SK, Canada
The grill outer panel(I assume you are talking about the entire headlight surround piece that accepts the center grill)should be painted body color. The front fender trim is incorperated into that piece and doesn't look right painted anything other than body color. ![](/ubbthreads/images/graemlins/Twocents.gif)
Paint the plastic center grill flat black instead of gray and the front end will look great. I also don't think it looks right when guys paint the Rallye hood inserts black. They should be body color as well. There is a small center piece that goes inside the hood louvers that I have seen people paint orange instead of just body color and that look prety good. This is just my opinion and you do what ever you want to YOUR car.
Hey burdar - wish I would have checked the thread before painting the front end!! Might have reconsidered the black. Not sure if I'm happy with it black...wouldn't be too hard to change it though... Thanks for the feedback and suggestions! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: burdar]
#180900
08/10/09 09:55 PM
08/10/09 09:55 PM
etek
SK, Canada
OK, so the mechs couldn't start it due to low oil pressure. Had it towed back ($80 again!) and pulled the engine again. Changed the oil pump and drive, ran up the pump with a drill to get 60lbs and also painted the intake blue to match while I was at it. Stuffed it back in and heres the result. Thanks again for looking! E-tek Engine Start up
