Re: Index racers ---- weight boxes? [Re: max_maniac] #1808747
04/21/15 05:25 PM
04/21/15 05:25 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I havent read up on the Grid. It was my understanding that the ignition was capable of slew rate, timing control and rpm control, but had to have the add on modules to control them on the car. That was why the add on modules were illegal.
Who knows..
I still run a msd 7AL2.
Re: Index racers ---- weight boxes? [Re: max_maniac] #1808933
04/21/15 09:16 PM
04/21/15 09:16 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
I don't know of anyone running a grid, but the digital 7 boxes can pull timing out and all that jazz can't they?
We still use the 7al2 as well.. And Russ we use that same gold weight box with free weights in 10 lb increments. The weight seems to do ok... Sometimes with more weight we just hook up better and go faster lol
Casey
Re: Index racers ---- weight boxes? [Re: Whompin_Wedge] #1810350
04/23/15 07:06 PM
04/23/15 07:06 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Looks like I need a weight box now......In the FRONT!!
https://www.youtube.com/watch?v=OnZEy3Ij76c
WIZE
In Car:
Re: Index racers ---- weight boxes? [Re: Whompin_Wedge] #1810382
04/23/15 07:56 PM
04/23/15 07:56 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Casey
That's exactly why I no longer use weight. I don't think any of us have enough power to need traction control. I know I don't.
Doug
Re: Index racers ---- weight boxes? [Re: max_maniac] #1810466
04/23/15 09:32 PM
04/23/15 09:32 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Russ, you just need some 50lb plates that can be bolted over the axles in the trunk, think you've seen that before, as far as the grid, I went to Mopars at the Strip and visited with a bunch of my old racing buddies this spring, didn't run the car just flew out. But some old friends of mine who run stock were running the grid, and its legal if its the one where you can just review your run, but you can make changes in timing also.
Re: Index racers ---- weight boxes? [Re: wyoming] #1810548
04/23/15 10:49 PM
04/23/15 10:49 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I have been slowing my car down from a high ten second car to an 11.50 car for many years now. Last year we tried 11.50 index racing and Won a Track Championship. I don`t use weight ( I`ve had one hernia surgery and don`t want another) but I use a Moroso throttle stop , mine is modified a little but it bolts to the corner carb bolt and can be set to restrict the throttle from opening all the way ,on my car the secondaries are barely opening and one turn is about 6 hundredths. A word of advice if you use it don`t just use the one bolt to hold it as it will turn slightly on the stud/bolt. I purchased the Jegs throttle cable/return spring bracket which also mounts to the carb bolts/studs and simply drilled another hole and added another bolt so it can`t move. I have considered a plate system but my results with my current set-up have been great.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
