Pentastar Emblem Placement and Bolt Painting #1807738
04/20/15 02:17 PM
04/20/15 02:17 PM
Oklahoma
Clay Fees Offline OP
Oklahoma
Good morning everyone. I was wondering if there was someone out there who might be able to help me figure out the exact placement of the little gold pentastar emblem on the fender of my 69 Road Runner. I believe it goes on the passenger side fender but if I am wrong on that please correct me.
Also, my body guy asked me if fender and door latch bolts (and the latches themselves) are body color, natural metal, or something else. I didn't know the answer to that question.
As alway, I appreciate all the help you all give me on this board. Have a blessed day.
Clay Fees
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1807824
04/20/15 04:01 PM
04/20/15 04:01 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
There should be 2 holes in the lower part of the passenger fender where the emblem attaches. one is the main pin hole with the locking tabs and the other small pin is just an alignment hole.
Fender bolts - body color
Door latches - I believe are gold cadmium
Door catches - I believe are silver cadmium
68 Charger R/T 440 auto
Re: Pentastar Emblem Placement and Bolt Painting [Re: wesgtx440] #1807973
04/20/15 06:46 PM
04/20/15 06:46 PM
Oklahoma
Oklahoma
Thank you for the help on the bolts and latches. I sure appreciate that.
As far as the pentastar emblem holes go, my fender first have any. I need to know where to put them if anyone has any idea where they would go. I'm thankful for all help.
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1808356
04/21/15 03:25 AM
04/21/15 03:25 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
If there are no holes, you could just remove the mounting tabs and use some thin double sided tape to mount the emblem?? I cant provide exact location info for a RR fender. Might be able to find a picture on the web and judge where it goes.
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1808953
04/21/15 09:31 PM
04/21/15 09:31 PM
Oklahoma
Oklahoma
I suppose I can snip the plastic studs and stuck it in there with a bit of silicone. I put my GTO crests on the fenders of my 66 and they've been on there 20 years
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1808988
04/21/15 09:57 PM
04/21/15 09:57 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Two sided tape works perfectly for that.
Ron
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1809087
04/21/15 11:48 PM
04/21/15 11:48 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
3M also makes a plastic emblem adhesive that I have used and is not as thick and more permanent than double sided tape, imo.
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1809163
04/22/15 01:59 AM
04/22/15 01:59 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here is a photo on a '68 b body fender.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1809272
04/22/15 10:43 AM
04/22/15 10:43 AM
Oklahoma
Oklahoma
This has all been extremely helpful. Thank you all very much!
Clay
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1809586
04/22/15 05:19 PM
04/22/15 05:19 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Is 6-3/4 a lot further away from 6-1/2 than 2-1/2 is from 2-1/4 ???
Or are my eyes bad, just want someone to check before someone drills!
Joe
Re: Pentastar Emblem Placement and Bolt Painting [Re: jlatessa] #1809622
04/22/15 06:12 PM
04/22/15 06:12 PM
Cincinnati, Ohio
Cincinnati, Ohio
Joe
I think it's because of the dog leg on the fender is tapered?
Re: Pentastar Emblem Placement and Bolt Painting [Re: Clay Fees] #1809994
04/23/15 09:09 AM
04/23/15 09:09 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I hope you're right, but I would ask for a re-measure before I started making holes.
Joe
