six pack air cleaner base #1806045
04/18/15 03:04 AM
04/18/15 03:04 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
I've had this base sitting around for a few years and it has me stumped…....would anyone know if it came on a production car or could it be an old direct connection piece?
Re: six pack air cleaner base [Re: mk_] #1806085
04/18/15 07:27 AM
04/18/15 07:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Looks as if it's a "cold air" package air cleaner
Re: six pack air cleaner base [Re: mk_] #1807179
04/19/15 08:07 PM
04/19/15 08:07 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Thanks DAYCLONA but I'm not so sure about that, the short outer edge doesn't look like it seals against anything and it doesn't appear to be modified.
Another interesting piece is it has a short strap that touches the rear carb float bowl when installed……..possibly a ground strap?
Re: six pack air cleaner base [Re: mk_] #1807378
04/20/15 12:32 AM
04/20/15 12:32 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
First I've seen like that and also,see no benefit from grounding air cleaner . shruggy
Re: six pack air cleaner base [Re: mk_] #1807395
04/20/15 01:01 AM
04/20/15 01:01 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
This looks to have once been a 340-6 TA/AAR baseplate that someone trimmed the outer 5 inches or so off and discarded.
All the contours are as correct as the 340-6 base.
Someone just decided to narrow it down.
The ground strap was used on the 340-6 TA base as well as the 440-6 and Hemi shaker bases
Re: six pack air cleaner base [Re: mccannix] #1807461
04/20/15 02:19 AM
04/20/15 02:19 AM
USA
rftroy Offline
rftroy  Offline
USA
I don't have that "strap" on either of my factory 340-6 air cleaners bases.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: six pack air cleaner base [Re: mk_] #1807565
04/20/15 10:22 AM
04/20/15 10:22 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Hmm...to maybe prevent a static electricity build-up as the base is
isolated from ground normally???
Joe
Re: six pack air cleaner base [Re: rftroy] #1807604
04/20/15 11:22 AM
04/20/15 11:22 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I should have stated "was used on some TA bases".
I believe I have a print somewhere that shows a date the strap was to be deleted on 340-6 only".
Re: six pack air cleaner base [Re: mccannix] #1809772
04/22/15 10:39 PM
04/22/15 10:39 PM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Thanks for the replies…...never stop learning on this site!
