Re: Index racers ---- weight boxes?
[Re: Whompin_Wedge]
#1810382
04/23/15 07:56 PM
04/23/15 07:56 PM
Posts: 9,889 MI, usa
dvw
MI, usa
I don't know of anyone running a grid, but the digital 7 boxes can pull timing out and all that jazz can't they?
We still use the 7al2 as well.. And Russ we use that same gold weight box with free weights in 10 lb increments. The weight seems to do ok... Sometimes with more weight we just hook up better and go faster lol
Casey That's exactly why I no longer use weight. I don't think any of us have enough power to need traction control. I know I don't. Doug
[Re: wyoming]
#1810548
04/23/15 10:49 PM
04/23/15 10:49 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
I have been slowing my car down from a high ten second car to an 11.50 car for many years now. Last year we tried 11.50 index racing and Won a Track Championship. I don`t use weight ( I`ve had one hernia surgery and don`t want another) but I use a Moroso throttle stop , mine is modified a little but it bolts to the corner carb bolt and can be set to restrict the throttle from opening all the way ,on my car the secondaries are barely opening and one turn is about 6 hundredths. A word of advice if you use it don`t just use the one bolt to hold it as it will turn slightly on the stud/bolt. I purchased the Jegs throttle cable/return spring bracket which also mounts to the carb bolts/studs and simply drilled another hole and added another bolt so it can`t move. I have considered a plate system but my results with my current set-up have been great.
