I will be order the parts for the upgrade as soon as i know exactly what to order.
The vac adv i should get is 10.5" not the 8? The reluctor looks ok, but for $6 i can change it out. The cap i'll be getting is hei because i have new wires that fit it.
Will i need new springs and are TD springs ok? Speedway kit for collar and shim, i can't find it on there w/s do you have a part #.
set initial then total (slots) to 36 (initial+slots), I get it but i may need some help.
Nacho modified the adv plate, is there a diagram or sketch of what was done?
peen the lower tang or weld it up, to be honest no clue!
I will need some help down the road.
thanks RapidRobert
