mounting drag slicks, Minneapolis north metro?
#1804755
04/16/15 06:07 AM
04/16/15 06:07 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Where have you had them done and cost? There are a few options I am going to check on, Norms tire in Little Canada, ($$$) Hoosier tire North in Rogers, Mn, Hi Tech Motorsports in Ramsey, Mn, and Schmidt oil in Chisago city, Mn. I bought Goodyear 2078 15x15x15 through Summit.
Re: mounting drag slicks, Minneapolis north metro?
[Re: gregsdart]
#1804780
04/16/15 08:16 AM
04/16/15 08:16 AM
Posts: 41 Northern MN
cedarmachine
Northern MN
I had Fisk Tire in North Branch do some and A-1 in Stacy as well.
Schmitty and Norms shouldn't have a problem either. Just whoever is closer.
Make sure that the put the stick on weights in the correct place so they don't hit the calipers.
[Re: gregsdart]
#1808469
04/21/15 10:43 AM
04/21/15 10:43 AM
gregsdart
Mike, the first one took over 16 ounces. Second one got by on 4. These are stick on weights on the inside of the rim, so they are only about six or seven inches from the center of the rim. Tires are 40.6 lbs each (tubeless), so I guess it isn't that much weight, considering.
[Re: gregsdart]
#1808479
04/21/15 10:52 AM
04/21/15 10:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I had 1 slick that took 19 ozs some years back... that was with a tube.. but thats the highest I've gone... and that was after trying to move the slick around a couple of times.. like you I do my own and I use the stick on weights then cover them with duct tape ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
