Re: Trans question
[Re: quickd100]
#1804597
04/16/15 12:12 AM
04/16/15 12:12 AM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
No disrespect meant, but why run a TF?
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Trans question
[Re: quickd100]
#1804872
04/16/15 12:20 PM
04/16/15 12:20 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
There is a 4wd version that has a pretty short tailshaft. Mid-'70s I believe when they used a short driveshaft between the trans and transfer case. Should be similar in length to a Glide.
Re: Trans question
[Re: slantzilla]
#1804878
04/16/15 12:29 PM
04/16/15 12:29 PM
Posts: 760 Canada
CTD5.9
Canada
There is a 4wd version that has a pretty short tailshaft. Mid-'70s I believe when they used a short driveshaft between the trans and transfer case. Should be similar in length to a Glide. A shorty kit from Cope Racing would make it even shorter. But the length on a truck short tailshaft transmission is 30.58" without the yoke, 34.12 with. Should be found in 72-74 4wd and I think all 2wd. I don't know how long powerglides are.
Re: Trans question
[Re: quickd100]
#1805134
04/16/15 07:07 PM
04/16/15 07:07 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
"Short" is a relative term; the shortest 727 tail that I've seen was used with the divorced transfer case circa early seventies.
Keep in mind that the factory tailhousing had to be long enough to contain the park/governor assembly. The aftermarket setup would likely be the shortest because it has no provisions for the governor.
Re: Trans question
[Re: quickd100]
#1806141
04/18/15 10:59 AM
04/18/15 10:59 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I did some poking around, and the best info I could glean was the TF with the aftermarket out put would be about 20 1/4? That is about 2 3/4 inches longer than a shorty glide. Any idea of how much room there is between the bell housing surface and the pinion ?
Re: Trans question
[Re: gregsdart]
#1806620
04/19/15 12:41 AM
04/19/15 12:41 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Might be fun to race at 10.00 though! Greg, I think I could race my truck at 10.00 and embarrass a bunch of lettered up cars doing it.Dave
