big block rear main seal. #1804409
04/15/15 08:30 PM
04/15/15 08:30 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Got new rear main seal from Summit a few minutes ago. Directions say soak side strip in mineral oil. Side strip are made of blue silicone (?). Thought rubber side strip went in the retainer dry and you oiled the block, at least with the orange ones. Anyone use the blue ones?
Re: big block rear main seal. [Re: Carsavior] #1804420
04/15/15 08:57 PM
04/15/15 08:57 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
What brand rear seal is it?
Got a pic you can post work
Re: big block rear main seal. [Re: Carsavior] #1804640
04/16/15 12:54 AM
04/16/15 12:54 AM
Monroe, LA USA
Monroe, LA USA
Can't figure out how to post a pic. Something different on here now. The package the seal came in said genuine Mopar parts.
Re: big block rear main seal. [Re: Carsavior] #1804826
04/16/15 10:49 AM
04/16/15 10:49 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
It's pretty straight forward and here's the "how-to". I'm still learning as well.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1799584
I'd like to see a pic of the instructions as well if you could.
Here's the Superformance Products retainer seal
and instruction sheet
Re: big block rear main seal. [Re: roadhazard] #1804827
04/16/15 10:52 AM
04/16/15 10:52 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Having issues posting the Instruction sheet. I'll get it figured out or copy & paste them for you thumbs
Re: big block rear main seal. [Re: Carsavior] #1805164
04/16/15 07:48 PM
04/16/15 07:48 PM
Monroe, LA USA
Monroe, LA USA
That's the puppy. Never saw a blue one before. Does it install like the orange one?
Re: big block rear main seal. [Re: Carsavior] #1805297
04/16/15 10:54 PM
04/16/15 10:54 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
It only took my 15 tries to post the instructions laugh2
Yes, they are installed in a similar fashion as the orange ones. DO NOT soak them in Kerosene or Mineral Spirits or you may just end up with a blue blob in your hands.
Mopar Performance was supposed to change the instructions with the addition of these new seals mad
Re: big block rear main seal. [Re: Carsavior] #1805439
04/17/15 04:50 AM
04/17/15 04:50 AM
Monroe, LA USA
Monroe, LA USA
Got it in tonight. Did like your directions said. Yes the Mopar instructions did say to soak them but I didnt. Tried half a dozen times to post a pic. Said it was too big. Oh well... anyways thanks for the help. - Pat
Re: big block rear main seal. [Re: Carsavior] #1805484
04/17/15 10:40 AM
04/17/15 10:40 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Fill sides with black sealant and install. Then after install use black sealant between block and retainer sides to fill the gap.
MLR426
