Re: Idle issue with 1000cfm 4150 carb
[Re: slammedR/T]
#1804994
04/16/15 03:14 PM
04/16/15 03:14 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I've been reading this since I'm also running a P-S 1000HP on my 414 that was originally on my 517B. Mine isa 3 circuit primary plate and the small block needed just a slight amount of tuning to idle. It's a "typical cold natured Chrysler Product" as one of my old mentors used to always say, once it warms up it seems fine. I think I'm at 88/6.5 and 94/plugged F/R, I've wondered would there be any major benefit to plugging the primary and square jetting (since I'm Foot-braking at 3000 off the 2-step so I'm really just launching off the Back shooters anyway). I'm thinking since the PV is vacuum/load sensitive just square jetting it might be more consistent and may actually make a little more torque. Thoughts?
BTW... I have nothing but High praise for Patrick, I gave him my BB 517 to SB 414 parameter changes and he told me where to jet.
[Re: justinp61]
#1805040
04/16/15 04:29 PM
04/16/15 04:29 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
IMO, you can't have clean hot and cold idle without a choke. Cold engines like to be rich (choke on) until they warm up (choke off). I have the hot idle on my 950HP nice and clean and just deal with it being cantankerous when cold. Idle gets better when warmed up but it is still too rich at idle when warmed up. Shoot I gotta go look at the air bleeds, be right back.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#1805041
04/16/15 04:31 PM
04/16/15 04:31 PM
slammedR/T
My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32
[Re: slammedR/T]
#1805098
04/16/15 06:06 PM
04/16/15 06:06 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 Have you checked the throttle blade yet to see how much transfer slot is showing? You may be able to lean it out with IAB and mixture screws. If not you'll need to change the IFR's which will also change the cruise afrs. The money I spent on my LM2 was well worth it.
[Re: justinp61]
#1805104
04/16/15 06:11 PM
04/16/15 06:11 PM
slammedR/T
My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 Have you checked the throttle blade yet to see how much transfer slot is showing? You may be able to lean it out with IAB and mixture screws. If not you'll need to change the IFR's which will also change the cruise afrs. The money I spent on my LM2 was well worth it. I haven't yet, I will check it either tonight or saturday as I'm still finishing up on the interior right now and want to get it done before saturday afternoon. I'm looking at the MTX wideband set-up
[Re: slammedR/T]
#1805113
04/16/15 06:24 PM
04/16/15 06:24 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
...That is the best performing carb I have ever had once I thru out all the jetting it came with and started over. Doesn't say much for the company you got it from, if it was supposed to have been tuned for your car when you got it. I have not had good luck dealing with him. Both of my carbs were way off, and I found him tough to deal with. This is why I decided to try a G3 Holly on my latest purchase. I will be getting that on the dyno soon, and I will take my SV1 with me, but it will be the G3 that wins I will bet.... My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 Scrap the #76 idle bleeds and switch to #70's.......That is for chevy calibrations as they idle a lot leaner. Mopars need fuel at idle. Me, I would remove the power valve and square it right up with 92's or 93's and then work the HS bleeds down a little towards #28's and see. Maybe go a #31 or #30 to start with after you have made a couple of runs squaring it up. Mine was much more responsive that way.
[Re: slammedR/T]
#1805152
04/16/15 07:39 PM
04/16/15 07:39 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 The 76 idle bleed is cos of a rich mixture and a 32 hi bleed is too big.
[Re: Thumperdart]
#1805208
04/16/15 08:52 PM
04/16/15 08:52 PM
slammedR/T
My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 The 76 idle bleed is cos of a rich mixture and a 32 hi bleed is too big. Got a suggestion where to start with the air bleeds?
[Re: Dragula]
#1805209
04/16/15 08:53 PM
04/16/15 08:53 PM
slammedR/T
...That is the best performing carb I have ever had once I thru out all the jetting it came with and started over. Doesn't say much for the company you got it from, if it was supposed to have been tuned for your car when you got it. I have not had good luck dealing with him. Both of my carbs were way off, and I found him tough to deal with. This is why I decided to try a G3 Holly on my latest purchase. I will be getting that on the dyno soon, and I will take my SV1 with me, but it will be the G3 that wins I will bet.... My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 Scrap the #76 idle bleeds and switch to #70's.......That is for chevy calibrations as they idle a lot leaner. Mopars need fuel at idle. Me, I would remove the power valve and square it right up with 92's or 93's and then work the HS bleeds down a little towards #28's and see. Maybe go a #31 or #30 to start with after you have made a couple of runs squaring it up. Mine was much more responsive that way. Idle is too rich now, but I like the block off power valve in the front and run 94 square idea.
[Re: slammedR/T]
#1805211
04/16/15 09:04 PM
04/16/15 09:04 PM
Thumperdart
State of confusion
My jets are 84 front and 92 rear with #76 idle air bleeds and Hi speeds are #32 The 76 idle bleed is cos of a rich mixture and a 32 hi bleed is too big. Got a suggestion where to start with the air bleeds? What size ifrs and how much t slot showin
[Re: Thumperdart]
#1805466
04/17/15 09:42 AM
04/17/15 09:42 AM
Streetwize
Weddington, N.C.
Can somebody respond to my question of the benefits of square jetting/blocking the PV in terms of throttle response/consistency for a 3000 rpm/stutter 2-step launch on a 5000 stall converter. Am I likely to see any real difference (60' et improvement) since I'm essentially shooting off the rear pump shot anyway? I mean it seems logical to me (take the potential PV "flutter" out of the equation and truly equalize the A/F ratio from F/R) but want to get my head around the real reasoning or something I'm not considering. I know it's easy enough to try but before I do I want to hear other opinions....thanks!
The 1000HP 4150 carb was originally on a 508" street driven Big block where the PV was beneficial for cruising.
[Re: Streetwize]
#1805469
04/17/15 09:59 AM
04/17/15 09:59 AM
Dragula
The 1000HP 4150 carb was originally on a 508" street driven Big block where the PV was beneficial for cruising. As I stated, I got a stronger signal and instantly better idle and throttle response, almost like it had a small vacuum leak, but I never found one and yet I checked many times. I do not trust the PV delivers fuel evenly with a nasty cam. With a street car, its probably a lot better, but when you have real duration and a real lack of vacuum signal I think its best to get rid of it. I have the best idle on this thing and yet my duration at 50 is over 300...... I run this carb on my 512 and the jetting and air bleeds posted above flat out works. I trap 110-111mph in the 1/8th with this thing. The way he sent it did not. And it took a while to sort it out, but its about as good as I think it will get and I want to focus on the SV1 a little.
[Re: rebel]
#1805939
04/17/15 11:09 PM
04/17/15 11:09 PM
Dragula
i had the same problem with my engine when it was cold, it took a few minutes of foot assisted idle to keep it running til it was able to run by itself. one day i used a higher grade fuel. instantly it ran like a regular streeter. no foot assisted idle, could select a gear without it stalling, the engine ran real nice even in our winter, (no snow). my suggestion, use a better grade fuel. Put #70's in for the idle air bleeds....start at 1 turn out on the idle screws.
[Re: Thumperdart]
#1806029
04/18/15 02:03 AM
04/18/15 02:03 AM
slammedR/T
I finally had a chance tonight after working on everyone elses car to mess with my R/T. I pulled off the carb and not touching anything from where I have had it. the transition slots have .020"-.030" showing on the primary and secondary throttle plates. What is the IFRS?
[Re: rebel]
#1806030
04/18/15 02:03 AM
04/18/15 02:03 AM
slammedR/T
It does this on my shell V-power 93 or VP 110 race gas, so it isn't a fuel issue.
[Re: Dragula]
#1806032
04/18/15 02:04 AM
04/18/15 02:04 AM
slammedR/T
The 1000HP 4150 carb was originally on a 508" street driven Big block where the PV was beneficial for cruising. As I stated, I got a stronger signal and instantly better idle and throttle response, almost like it had a small vacuum leak, but I never found one and yet I checked many times. I do not trust the PV delivers fuel evenly with a nasty cam. With a street car, its probably a lot better, but when you have real duration and a real lack of vacuum signal I think its best to get rid of it. I have the best idle on this thing and yet my duration at 50 is over 300...... I run this carb on my 512 and the jetting and air bleeds posted above flat out works. I trap 110-111mph in the 1/8th with this thing. The way he sent it did not. And it took a while to sort it out, but its about as good as I think it will get and I want to focus on the SV1 a little. Since I also do street driving would blocking the front PV be a bad idea for me?
[Re: slammedR/T]
#1806037
04/18/15 02:36 AM
04/18/15 02:36 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Removing the pv on a street driver will cause over fuelling at lower rpm and cruise rpm . Some like to set dyno af ratio then fit pv and jet down some . I have thought to change air bleeds but never got there - slackarsed i guess . I am happy to accept a larger cam ,big carb and single plane will often lead to a rough low idle when dead cold .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
