Dampner Nut #180405
01/01/09 01:18 PM
01/01/09 01:18 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Which way does the nut turn on the crank that holds on teh dampner? Also what is the best way to get the nut off? And what is the best way to get the dampner off?
Re: Dampner Nut [Re: wtucker] #180406
01/01/09 01:33 PM
01/01/09 01:33 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The bolt turns counter clockwise to remove, easy with 1/2 inch impact, and then a balancer puller to remove.
Re: Dampner Nut [Re: wtucker] #180407
01/01/09 01:34 PM
01/01/09 01:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It is a bolt and it unscrews normally. You should use a puller for the dampner. You might be able to borrow one from a good parts store. O'Reilly's loans tools as well as some other chain auto parts stores.
Re: Dampner Nut [Re: wtucker] #180408
01/01/09 01:45 PM
01/01/09 01:45 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
if ya cant get an impact in use a wratchet or with a breaker bar and a big hammer hitting the handle.i think at 1 piont i put a 2x4 next to the starter ring on the torque convertor to keep the engine from turning.
Re: Dampner Nut [Re: blownzoom440] #180409
01/01/09 01:53 PM
01/01/09 01:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have taken a breaker bar with a socket to remove the bolt by putting the end of the bar against the top of k member on the drivers side and bumping the starter at the relay.
Re: Dampner Nut [Re: buildanother] #180410
01/01/09 02:03 PM
01/01/09 02:03 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
what size is the nut?
Re: Dampner Nut [Re: wtucker] #180411
01/01/09 02:10 PM
01/01/09 02:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think the BOLT is 1 1/4".
Re: Dampner Nut [Re: stumpy] #180412
01/01/09 03:43 PM
01/01/09 03:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
After you remove the bolt take the washer off it and re install it almost to the surface of the damper and use a 'elcheapo' steering wheel puller to slide the damper off. The reason to put the bolt back in is to use the head of the bolt for backing for the puller base. with out it for a backing the tip of the puller will fit into the crankshaft and do a number on the internal threads of the shaft. The damper will slide right over the bolt head without the washer on it.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
